helee
Lilburn, GA
I'm in the process of replacing the weather stripping rubber around my slide. When I remove the old rubber the adhesive tape stays on the frame and doesn't come off with the rubber. I have a couple of products, Goof-Off, lighter fluid, acetone, etc., that removes the adhesive, but I can't get the actual plastic tape off to get to the adhesive. Any ideas?
Winnie SS '08
Delaware
Hi,
I use WD 40 to get off any kind of sticky anything! It always works for me. Then I clean off the area really well before I apply anything new.
Just an idea, hope it helps.
Winnie SS '08
coolcamp
St. Louis
3-M eraser wheel. Find them at local auto/paint/body shop. Around 14.00...best, safeset, and easiest way to remove adhesive....period.
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
LewMichele&Paws
Cowlitz County, WA
Perhaps the slightest of slices in the tape with lighter fluid then applied will allow the glue underneath to separate so the tape will pull off in sections. Good luck, I know many products work but I have used lighter fluid for so long on so many different items that I haven't gone to anything else.
Lew
Don't lose your head...to save a minute...you need your head...your brains are in it...Burma Shave
States visited in our RV...
bacollins
Lawrenceburg, IN
+1 on the 3M Eraser Wheel.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'92 Honda 750 Nighthawk
budda
Lambertville , Mi 48144
3M also has an adhesive remover. Automotive paint stores have it. I removed the vinyl stripes on our boat a few years ago. I tried several other removers and the 3M worked the best. It seems to soften the vinyl and disolve the glue.
06 Adventurer 38R
Carol, Roy and our Abby cat
tommy wilson
southern ca, usa
laquer thinner.
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
alpenliter
Olympia WA
I've done the same job with lousy results with my old standby 3M Adhesive Remover that usually cuts right through the goo. But like you said, the tape shields the remover from doing its job. I've heard great results from the 3M erasure wheel that the guys above have suggested, so that's what I would try.
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
