cncolyer
CA
Anyone been able to find a K & N Filter for the 5500 Duremax Engine?
If so do you know the part #
Thanks,
Cliff
mikehart92
Oklahoma
Do you really want to?
Been proven time and time again that there are no gains to be had and lots of problems that can arise from them.
Mike
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
JohnInAz
Arizona
I recall finding this stuff on the K&N web page. You have to install a different housing for the air filter as they don't have a direct fit product. They have this kit.
2007 Jayco Seneca 34SS
2006 Jeep Grand Cherokee toad
ronfisherman
SE Michigan
Have you check the filter in the Kodiak. 7.5" diameter X 18" long. Lot larger than the pickup filters. If you want to get something from K&N get a Filter Minder if your Kodiak does not have one.
K&N does not list a filter for 2007 & 8. 2006 part # is 77-3064KTK
Air intake on Kodiak is from passenger side of hood on the outside.
Saf-TTE tire monitor
pauldub
North of Seattle
K&N will pass more dirt Air Filter Test
kendall69
Palm Springs California
I put a K&N on my vehicle and the silica numbers on the oil analysis shot WAY UP ( silica = sand ) took it out all the numbers went to normal. Never again for me.
2002 - Bigfoot M-29G, 2004 Jeep Rubicon Toad
paulin
No. CA
Everything I've read about the stock Kodiak air filter is that is flows very well and an after market one is not indicated.
Paul
Paul & Linda
2007 Jayco Seneca HD 34SS Duramax
2005 Saturn VUE
"Monty", "Maggie" & "Murphy" the mighty Shih Tzus
FMCA #F375077
cncolyer
CA
Cool, thanks for the feedback I think I'll stick with my stock filter and save a hundred bucks.....
Cliff
Home Skillet
Pearland Texas
......and save your motor.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
