RV.Net Open Roads Forum: Toy Haulers: Heating for a "poor mans" toyhauler
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Heating for a "poor mans" toyhauler
Enigma66
Central Oregon
Posted: 07/19/08 01:42am Link  |  Quote  |  Print  |  Notify Moderator
We have a 8.5 x 20 Cargo trailer that we haul our ATVs in and camp in during the summer.
During our outing last week at the Oregon coast it got uncomfortably cool at night while sleeping so I am looking for an inexpensive solution as it will be used infrequently.
I was looking at this. It is certified for indoor and RV use. I purchased the unit along with a battery powered carbon monoxide detector ( I may actually install 2 CO2 detectors as a fail safe) They are relatively inexpensive. After I got it home I noticed a disclaimer on the box " do not use while sleeping". The website does not mention this but it is on the box.
http://www.mrheater.com/productdetails_extended.asp?catid=41&id=24
My research also turned up these but they are more expensive and would require a installation of a 20# tank on the tongue and plumbing inside the trailer.
http://www.camco.net/Menu.cfm?SupCategoryId=10200&SubCategoryId=257
http://www.rvpartscenter.com/ProductDetail.asp?PID=34729&SID=11&DID=84&CID=244
The thing I don't get is RV sites have them advertised on the same page with the rest of the heaters.
http://www.rvwholesalers.com/catalog/home.php?cat=86
GregsSD
Santa Rosa, CA.
Posted: 07/19/08 01:58am Link  |  Quote  |  Print  |  Notify Moderator
I was in the same situation a few years ago with a 24' trailer and I found a Suburban RV furnace and mounted it at the front of the trailer and it worked great.
2005 Ford F-250 4x4 Powerstroke Diesel
2002 Weekend Warrior FS2600
2006 Yamaha Raptor 700 SE
1987 Suzuki LT500 "Quadzilla"
2003 Kawasaki KFX700 Quad
Yamaha Warriors, Blaster, & Suzuki LT50
Kawasaki 550 & 650 Jetskis
Hardtime01
Central Fla
Posted: 07/19/08 05:19am Link  |  Quote  |  Print  |  Notify Moderator
I use to duck hunt out of an old TT that had no heater. I just turned on the stove (propane) and cracked a window for ventilation and never had a problem. I think you would be fine as long as you vented the room somewhat...Mark
nny12972
NY
Posted: 07/19/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Ya' get what you pay for.....heating something like 800cu.ft. of uninsulated T isn't a small chore---and Mr. Heater will eat up your O2.....odds are you won't take that "big sleep," but I'd be careful, and provide some ventilation....
(Heaters heat---they all SHOULD be on the same page---shouldn't they?!)
J
reno82
Cardiff by the Sea, CA
Posted: 07/19/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
First off have you thought about insulating your cargo trailer, including the roof? If you haven't done it yet, it will help during heat and cool. Second, how about an electric heater and small generator. I use an electric heater even though I have forced air gas, it saves the gas, it's safe, and when I'm hooked up at a park I'm using their electricity
sandblast
salt lake city utah
Posted: 07/19/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
reno82: Please don`t suggest anyone running a generator at night for
the electric heater.
insulation in the trailer--very good.
E.P.
Enigma66
Central Oregon
Posted: 07/19/08 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
We have thought about insulating the trailer. We did not know if that would be enough. Obviously it would help. Temp got down to about 45-50 deg the night we were uncomfortable.
I do have a small Honda generator. Running it all night would make me nervous with the emissions but each person has their own level of comfort. Besides, where we camp quiet rules are enforced @ 10pm generators included.
Vulcanmars
Naples, FL
Posted: 07/19/08 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
We also heated an old hunt TT with the propane oven and windows cracked open. We did use cO2 detectors, one over each bed. Did it for years.
I would have two stand alone battery powered CO2 detectors just like you plan.
Night, night.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
nny12972
NY
Posted: 07/19/08 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I came up with an R22(certified) doing my CT to TH conversion(profile).....1 1/2" spray foam(commercial outfit), another 1 1/2" foil-face foam board, and final wall board....4" spray foam under the floor, except just an inch below my tanks......total investment was under $200 with my labor shaving the spray foam....at freezing, my 25K btu Suburban will run about 1 hour total in 8 hours---at zero, it runs about 2 hours with refectix on the windows......in summer(now 85), I run the A/C for 10 minutes or so before I crash to knock the RH down a bit......you'd be amazed what that closed-cell foam does compared to glass......even a 1 1/2" foil-face foam would do you wonders---particularly a layer under the floor.....and it's a piece of cake to install it----I didn't even glue mine----cut it real tight and high quality taped the seams.....I did cover the underside with PVC screwed to the frame......
Enigma66
Central Oregon
Posted: 07/19/08 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
nny12972
You have PM
