Ken Grist
CT
Had a bad alternator on a freightliner/cat 350 Winnebago rig. Had it rebuilt. Works for awhile, then shuts down. If you leave it sit, it will return to normal. Sometimes overcharging, sometimes undercharging, sometimes nothing. Thoughts?
Ken
SCOMP225
Brownsburg,Indiana
Ken,
Sounds like the regulator is going.
I was coming across Ohio a few weeks ago and mine( Delco 22SI) did the same thing, it would show 13volts and jump to 15.5volts.
Fortunately I carry a new spare and pulled into a truck stop and changed it out.
All back to normal.
Take to an Alternator shop.
Chuck
1992 American Eagle
Security: Sam- Black Lab/Glock When He's asleep on the couch.
TEXAS
Centerville Tx
I would also look at the regulator.
Ken Grist
CT
I appreciate the regulator feedback....would you expect the regulator to have been looked at when the unit was rebuilt, or am I just showing how much of a novice I am? LOL
Ken
DtBt
Saint Leonard, MD
Check out the connections on the back of alternator. A loose connection may be the culprit.
Dennis and Barb
1999 Monaco Windsor 40 SS
97 Jeep Wrangler toad
tom_kat
way upstate new york/lake george area
to much heat with not enought cooling will cause the regulator to act up.when you change out altanators its always good to use the fan from the origanal or make sure its the same there is differant cooling fans they use for more air flow.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
TEXAS
Centerville Tx
Ken elecrical parts are like light bulbs,never know when they will go out. Most of the time it is the day before you go on vacation and the wife is nipping at your heals.Any time you need help just ask. All of us here have to ask at sometime. I have been at this for forty years and still learn every day.
Ken Grist
CT
Texas et al,
Ok, well, forget the "rebuilt" avenue, although some will swear by it...I was headed out to Myrtle Beach a week ago and got fed up with the alternator stuff, so swung by Freightliner and had a new one put in....OH YEAH...2,000 mile round trip, no issues...enjoyed the sunny south....I am happy again!
Ken
MrWizard
Van Nuys, Ca
Ken Grist wrote: I appreciate the regulator feedback....would you expect the regulator to have been looked at when the unit was rebuilt, or am I just showing how much of a novice I am? LOL
Ken
delco alternators and clones have the regulator built in, it can suffer from heat fatigue, they have built in thermal control to reduce output as the alt warms up, when mine is cold it will put out almost 15volts, but drops to less than 14 than after the engine warms up
many other alternators use an external regulator, that may not have been checked when the alt was rebuilt
Connected via Verizon Via LG Dare VX9700
Maximum memory has been reached !
