RV.Net Open Roads Forum: Tech Issues: Water heater problems
 > Water heater problems
4_Hikers
Tennessee
Posted: 07/19/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone, i have a problem with my Suburban water heater(2005). last weekend in preparation for a weekend trip, i plugged the RV into my normal 120V/15 amp receptacle only to run the fridge in preparation, but didn't realize that my water heaters' electric heater switch was on. when i got to the campground and got the RV set up, there was no hot water from the electric setting, but it worked fine on the gas. i feel like i may have burned the heating element up, but am not too sure how to verify that. anyone run into this problem? is the fix as easy as going to camping world and buying replacement parts?
Thanks for any advice you can give.
pulsar
Lewisville, NC
Posted: 07/19/08 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
JFG
TN
Posted: 07/19/08 08:00am Link  |  Quote  |  Print  |  Notify Moderator
If tank was dry, you probably burned the element out. Verify that circuit breaker did not trip. if ok, Check continuity on the element.. a good element should read 10 ohms. Replacements are available a CW and are easy to install.
Fred
robatthelake
Vancouver Island
Posted: 07/19/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Also check that tiny switch on the actual heater!
The Element is usually less expensive at Lowes or Home Depot Etc. Just remove the Old one "Power Off... Tank drained" then take it along to find a close match!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
SPRey
Orange County, Kalifornia
Posted: 07/19/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Probably toasted the element...cuz the gas does not use the electric heating element. Not too nasty to replace...but a pain.
Tim & Sue
Gerry (GSD) & Jammer (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 37 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Red Wine anyone?
nbounder
Arizona mountains
Posted: 07/19/08 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the 'tank drained' step in Rob's reply.
4_Hikers
Tennessee
Posted: 07/19/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
OK, i got the element and will install it tomorrow. It does look like a pain to replace. Thanks to everyone for the assistance!
