RV.Net Open Roads Forum: Tech Issues: Bounder windshield wipers
 > Bounder windshield wipers
emersonhbest
Mesa AZ
Posted: 07/19/08 10:21am Link  |  Quote  |  Print  |  Notify Moderator
We have a'99 Bounder which we bought in 2000 with 5000 miles. There have been 3 times that the wipers won't turn Off either after I've turned them ON or most recently they've begun operating when starting the engine! The first 2 times the Fleetwood dealer replaced the Wiper's Controller. I have not had a repair done as of this writing. I merely disoonnected the power and of course that fixes the problem until we encounter RAIN (which is rarely here in AZ). Any suggestions? Thnx
Jim&Peg
Central Ohio
Posted: 07/19/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
The wiper motor has a park switch. When you turn off the wipers, the park switch keeps them running until they get to the park position then shuts off. That switch could be stuck. The other possibility is that on some the switching is on the ground circuit. If that is the case, a short to ground on the wire to the switch would keep them running.
pulsar
Lewisville, NC
Posted: 07/19/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
