RV.Net Open Roads Forum: Technology Corner: Digital TV change over
 > Digital TV change over
2RVers
Posted: 07/19/08 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
If one has a digital TV currently receiving its signal through the usual RV antenna, will it require the converter box next year?
Rob and Jet
2000 Ford F550 with custom bed
1998 Jayco Designer 3710 fifthwheel
Fred and Barney de Katz
RoadAbode
Philadelphia
Posted: 07/19/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Same antennae Signal as Home...so yes.
The RoadAbode Crew
Mike ~ Amy ~ Kimberly ~ Emily
RoadAbode Blog
axle234
Pasadena,Md.
Posted: 07/19/08 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
NO if the TV is digital... in my area my digital TV is already receiving Digital Stations. I just got the box (converter) for my TV in the RV. Though my Mh is a 2008, Fleetwood chose to put a older analog set in the coach, now I need a converter. With out going in to the back of the TV through the cabinet I'll need a splitter and a A_B switch to use both - Analog and or Digital.
Happy Rving!
axle234
2008 Fleetwood Fiesta
Toad- 99Honda CRV
USAFBILL
Alabama
Posted: 07/19/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
No...only if you use the older analog TV
BublHead
Bremerton, WA
Posted: 07/19/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not if you are receiving digital signal now. The converter is only for old analog tv's.
Lower all mast and antennas.
If you don't care where you are, you are not lost!
2000 GMC Sierra 2500HD 4X4, SLE, 6.0L, 4.10, Prodigy
2006 Sprinter 314BHDS
TTN/LTR
Wife, two girls, and.........Me
My Pics
myRVspace.com
fla-gypsy
North Florida
Posted: 07/19/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
No you are good to go. Digital tuners require no further action.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Wherever I happen to park
Posted: 07/19/08 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
You said you have a DIGITAL tv.. If you have a DIGITAL TV you do NOT, repeat NOT need a converter.. It has one built in.
You only need a converter if your TV does NOT have digital ability.
NOTE: HDTV and DIGITAL are NOT the same thing.. Though MOST HDTV's (if not all) will be Digital.
SCVJeff
Santa Clarita, CA.
Posted: 07/20/08 03:21am Link  |  Quote  |  Print  |  Notify Moderator
ANY HDTV receiver is digital by default.
Jeff - WA6EQU
philrush
Virginia
Posted: 07/20/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Im also baffled about this.
I have an anolog set, and know that to use a converter box.
My confusion is how to hook it up.
As I said, I have an anolog set that is connected to a DVD/surround sound system.
Do I connect the converter between the incoming antenna cable and the dvd player?? or between the dvd player and the rv set?
Im hoping that the answer is between the incoming antenna cable and the dvd player.
Thanks in advance
phil
SCVJeff
Santa Clarita, CA.
Posted: 07/20/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I am assuming that the DVD Surround system is just a player, and the TV only gets a video connection from it, correct?
If that's the case, the converter box is between the antenna and the TV. The cheap couponed boxes will not output (true)5.1, but your Surround Sound most likely has positions to synthesize stereo pretty well. In that case you would need a stereo RCA-RCA jumper from the stereo out from the converter to the surround.
