selswood
Miami, FL.
Leeroy wrote: I test drove a Monaco Cayman today, my first ride in a DP. I liked the quietness of the engine, but was surprised by the ride being stiffer and bumpier than I expected. The salesman said it would be smoother loaded????? Is this true DP owners?
No It has nothing to with been a DP
With air bags you have a ride hieght adjustment if it's not set right it will be a stiffer ride. If there is no air in the air bags it will be a stiffer and bumper ride. Go drive the same MH and make sure the air bags have air in them. with a motorhome with air bags when you park it at a campground you dump the air bags to level it. If you dont flip the switch to fill the air bags backup when you leave you will have a stiffer and bumper ride. I have driven a dump truck for many years with air bags on it and when I dump it you have to dump the air in the air bags and if you dont fill the air bags backup it is a ride you do not want to take. I now have a MH that is a DP with air bags and the first time out when I left the campgrounds to come home I forgot to flip the switch to fill the air bags back up and it was a stiffer ride back home.
2007 National RV Tropi-Cal
2004 Jeep Wrangler
Economical Handyman
S. California
Sorry Leeroy for this question.
But is this normal on some units you have to "flip a switch to fill the air bags"?
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
fourfurz
Memphis
Economical Handyman wrote: Sorry Leeroy for this question.
We have no switch. They fill automatically.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
Big Katuna
Deland, FL
My 05 Freightliner has a switch. You drain the air before you level.
My Kharma ran over my Dogma.
Leeroy
Thousand Oaks, Ca
This one has no switch to fill the bags, it does have one for dumping the air with engine off, but nothing inthe way of filling them... that's automatic.
I just hate to spend the $$$ and not be happy with the ride. Although, its no worse than my gasser, but do the other pros out weigh the cons?
'04 Fleetwood Flair 33R
99 Jeep Wrangler
Blue Ox Aventa II
Big Katuna
Deland, FL
If they won't let you adjust the tires, I would test drive a different chassis. My FL test drove ten times better than my gas coach. It is night and day better than the gas chassis. I wouldn't buy it if your not comfortable with the ride.
