RV.Net Open Roads Forum: Tech Issues: New Battery
 > New Battery
Cherokee Gypsy
lindale texas usa
Posted: 07/19/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing 12v.battery on my 5er. Which post do I hook up first so I dont fry anything.It only has 1 battery.Thanks in advance CG.
Jim, Fran and Fancy the Schnauzer (The real boss)
06 F250 Super Duty (SC) V10 410 LS
04 Crossroad Cruiser 5'er
Reese 16K
Rotochoks, timbrens, bedsaver
Gone With the Wind
smkettner
Posted: 07/19/08 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Positive first is my vote.
PopBeavers
San Jose, CA
Posted: 07/19/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
What ever wire is connected to ground (the frame) is always connectd last. It is also disconnected first.
The reason is that when connecting/disconnecting the hot wire, if you accidentally touch the wrench to the frame you do not want it to spark.
So sayeth my autoshop teacher a very long time ago.
Wayne in San Jose
TV1:2002 Chevy 1500HD 4wd Crew Cab,Valley Odyssey brake ctlr,McKesh mirrors
TV2:2008 GMC 2500HD long bed 4wd Crew Cab,GMC brake ctlr,GMC mirrors
TT:Trailmanor 2720
Honda 2000
Yamaha WR250R,Polaris Sportsman 700 X2,Polaris Scrambler 500
DUTCHTREAT
north port, fl
Posted: 07/19/08 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Good answers. But you don't need to worry about frying anything (except your wrench) no matter what cable you put on first.
To avoid any arcing when the last cable connection is made, make sure all the 12v equipment is turned off.
Wherever I happen to park
Posted: 07/19/08 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
The standard practice is to hook up the negative last
You may wonder why
in fact it should (in theory) make no difference
However if you have negative disconnected and, as you hook up the positive, your wrench slips and 'Shorts" the positive to the chassis..... Nothing happens. You see there is no path to ground for the power to flow
And if while connecting the negative,, Your wrench slips and shorts NEGATIVE to chassis.. Who cares.. The negative wire is doing that anyway
But if you hook positive up last,, And your wrench slips and shorts to the chassis.. It may well melt.. WHILE YOU ARE HOLDING IT
This is not good.
bkbajb
Queen Creek, Arizona
Posted: 07/20/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Negative off first and on last.
Alan, Brenda, Kyle
Queen Creek, AZ
2007 F-250 XLT Supercrew V-10,w/tow command,4.30,Equalizer hitch, WD bars
2008 Jayco 26BHS
 > New Battery
