RV.Net Open Roads Forum: Truck Campers: 3/4 ton vs. 1 ton questions.
 > 3/4 ton vs. 1 ton questions.
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 07/20/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Rawhyde wrote:
...The one thing I have noticed between the one ton and 3/4 ton trucks is the turning radius.
It takes a LOT more room to get that one ton truck turned around than a 3/4 ton truck.
That Furd F450 turns sharper than any other one ton truck out there (pick up truck, I know the HD Volvo's turn sharper) But I just cant afford the price.
In the newer Fords there is no difference in turning radius between a (same length) F250 and F350 SRW. Even on the F350 Dually there is a "wide track" front axle (basically the F450's) that allows for a sharper wheel cut for a reduced turning radius.
Technically the F450 is not a 1ton.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
Nemo667
Louisiana
Posted: 07/20/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Steve_in_29 wrote:
SoCalDesertRider wrote:
On the '05-up trucks, I will venture to guess the main difference is the springs. As far as I know, the axles, brakes and frames are the same and the wheels and tires can be swapped easily enough.
Here is some info from an accepted expert on thedieselstop:
Re: Differences in F350 and F250 4x4s
Originally Posted by Rockin_S
Other then the spring rate is there much difference between the F250 and the F350s?
Depends on the year.
Since you asked the question in the '99-up forum, I'll assume you mean '99-up.
For all '99-up PSDs, there is no difference in the front spring rate between identically-optioned F-350 SRWs and F-250. But pickups with different options can have different front spring rates. So an F-250 could have higher-capacity front springs than an F-350 SRW with different options. Go by the front spring code.
For the '99 models, the rear springs and the rear axle were different. Stock tires were different, but the F-350 SRW tires were available as options for the F-250.
Beginning some time in the Y2K model year and continuing through the '04 model year, Ford began installing the same rear axle and rear springs on most F-250s as were standard on the F-350 SRW. Stock tires were still different, but again the F-350 SRW tires were optional on F-250s. So for many pickups, the only difference in identically-optioned F-250s and F-350 SRWs was the spacer block in the rear suspension of 4x4s. F-250 4x4s had 2" spacer blocks, and F-350 SRW 4x4s had 4" spacer blocks. (There are no spacer blocks in 4x2s.)
For '00 thru '04 models, check the spring code on F-250s. If the rear spring code is "B", then you have the same rear springs as F-350 SRWs. But if the rear spring code is "A", then you have the lighter F-250 rear springs.
But beginning in 2005 model year, there is a definite difference in the F-250 and the F-350 SRW. The rear axle is different. The rear springs are different. Stock wheels and tires are 17" on the F-250 and 18" on the F-350 SRW. But still you could order F-350 SRW tires and wheels on F-250s, and many did.
Tires and wheels, yes. Rear springs and rear axle, no. F-250 4x4 longbed PSD 4x4 has 10,000 pounds GVWR. F-350 SRW longbed PSD 4x4 has 11,500 GVWR. The difference is in the rear springs and rear axle weight capacities. Everything else, including frame, brakes, front springs, shocks, engine and tranny are the same.
Here is the axle specs:
There are other differences in the 05-07 F250 and F350 See Below:
The Rear Axles are different between the F250 and the F350 SRW. See below from page 27, Rear Axel Specs (about half way down)
Cut and Paste this URL into a browser
https://www.fleet.ford.com/truckbba...iessd-ms_06.pdf
Axle Shaft — Spline Minor Dia.(in.)
F250 F350
1.36 1.50
— Spline Major Dia.(in.)
F250 F350
1.50 1.57
— No. of Splines(Hub End)
F250 F350
35 37
Having trouble with that link Steve. It may be because it is a http(s) and requires a password or authorization of some design.
2007 F-350 SRW 6.0L Auto CC SB 4X4
2006 Outfitter Apex 8, 220W Solar and 3 AGM's
cewillis
Tucson, az, usa
Posted: 07/20/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I agree with bigger is better on whether to buy a 250/2500 or 350/3500 SRW, may as well get the one-ton cause there really is no detriment to having the one-ton over the 3/4-ton and you get the 'official' increased GVWR sticker on the door to satisfy the weight police.
The only exception that I know of is that GM doesn't make a shortbed 3500 SRW.
Mainecoon
Meadville, PA 16335
Posted: 07/20/08 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I have a 07 Chevy dually Duramax full four door and eight foot bed and four wheel drive. I live in an area where we have lake effect snow and have not had any trouble in the snow with four wheel drive. I drive it all the time and the biggest problem is the length. Sometimes I will have to back up four times to park, but usually that isn't case. It also corners nicely with the extra wheels on the back and that is with or without a load. The only thing I will do when the tires wear out is to put bigger ones on.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like in that axle comparison they're comparing the 11000-lb 37-spline Dana 80 in the DRW F350 (and some F450's) to the 35-spline 9750-lb Sterling/Visteon 10.50" in the F250/F350SRW trucks. Visteon listed the axle specs as the same for F250/F350SRW last time I checked.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
realter
Lincoln, NE 68510
Posted: 07/20/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I disagree that duallies are bad in mud and snow. .
Living in San Diego, I question how much you have driven in snow!!
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I came from Flagstaff, AZ. 7000' elevation and snow...
FF1063
LI, NY
Posted: 07/20/08 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
scot_douglas wrote:
Thank you for all the replies, especially that DRW trucks have difficulty in mud and snow...
I use my dually in the snow and on the beach, I engage the 4x4 to avoid any 'difficulty'.
AF 990 / DRW 3500
realter
Lincoln, NE 68510
Posted: 07/20/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Very smart move. That area of the country is one of the most beautiful ive ever been to.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'd like to be moving back that direction some time in the next few years. I do miss seeing pine trees and 4 seasons...
