RV.Net Open Roads Forum: Fifth-Wheels: Under the 5er
 > Under the 5er
plauterer
Manitoba, Canada
Posted: 07/20/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
You will find out very fast that the foam flies in a lot of places you don’t want it on, mainly you. I have used it more than once and will say my experience has been very much a comic opera as I seem to get it in my hair, face, ears, and mostly on my cloths. It does not wash out either. Use as much face protection as you can and old disposable clothing. It can do a marvelous job of sealing holes. Give consideration to low expanding and high expanding types as some areas may be better served by one or the other.
Good luck in your work.
Dayle1
Spicewood, Tx
Posted: 07/20/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the biggest holes for critters are the slide-out mechanism thru the frame rails and those holes can't be sealed. Other holes are thru the pin holes of the landing gear legs and up into the basement.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'03 GMC 2500HD D/A EC SB, Jordan controller, custom RKI bed/hitch, Putco boards, TF 45gal tank, grey Speedliner
'04 CrossRoads Cruiser CF29RK, Mor/ryde IS, Carefree Eclipse 12V awning
Rig Photos
catadjuster
Amarillo, Tx
Posted: 07/20/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I was checking out the brakes and noticed that the spring hangers on the equalizer between the axles are almost worn out. Both hangers on only one side wearing. The top bolt holes are almost worn through. Getting that fixed tomorrow. Hate to think about the end result if one had failed.
04 Crossroads Silverado SF36MK, 5th Airborne pinbox
04 Dodge Quad Cab Long Bed 5.9 HO
Banks Monster Exhaust, Firestone Ride-Rite Air Springs
Fulltime
National Catastrophe Insurance Adjuster.
Home is anywhere at any time. Currently in Niagara Falls Area
wacochran
Jacksonville, Florida
Posted: 07/20/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
On using the steel wool make sure it is stainless steel wool. Standered steel wool will rust away.
2007 Kodiak 4500 Hauler
2008 Carrige Cameo 5th wheel
KSadler1
Albuquerque, NM
Posted: 07/20/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than steel wool, get the copper type scubbing pads that look like balled up wire mesh. Steel wool will rust. Push the mesh into the holes and then spray your expanding foam into the mesh. It will mix with the wire mesh and the copper wont rust like steel wool.....
Ken
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
RollingRockTX wrote:
SoCalDesertRider wrote:
You might want to use steel wool instead of expanding foam. Mice will have a party with that foam. They love stuff like that. They really took a liking to the fiberglass insulation in the walls of my old camper, pulling it out of the walls and carrying it to their nests behind the appliances and tanks.
Interesting idea about the steelwool
How do you attach it? Just stuff it?
Yes, stuff it up into the spaces tight.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
I should have said stainless steel wool, yes, that is a very good point about the rust. That copper one is a good idea too.
 > Under the 5er
