RV.Net Open Roads Forum: Fifth-Wheels: Cougar electric landing gear dead
 > Cougar electric landing gear dead
Coongoola
Australia
Posted: 07/19/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hi there from Australia,
Just had a call from a friend in Western Australia who is picking up his Keystone Cougar from a holding yard for the first time. It's a Sunday here in Oz and he can't ring anyone so he posted on my website.
Appears his legs are either dead or the battery is flat. I don't know at this stage. Is there a separate fuse that controls the legs and where would this be located ?
I've suggested that it has to be either a flat battery or a blown fuse. My Okanagan has old fashioned wind down legs so I don't have this problem.
Sorry to sound a bit vague but he is new to fivers and new to this particular van also.
Pat Robinson
Pat & Cheryl Robinson
Mid North Coast, NSW
Australia
weekendrvers
Iowa
Posted: 07/20/08 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Hi yes you have a 40 amp fuse for the landing gear we always carried spare ones because they blew often~ He will find the place for the fuse in a small box by the moter of the landing gear`Sandy
Coongoola
Australia
Posted: 07/20/08 02:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your quick reply Sandy
Cheers from down under
Pat
colleen&rich
Lafayette, Louisiana
Posted: 07/20/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the battery is up to the task. If it is out of water or giving off low voltage, you will have a problem.
Hope you get working!
Rich
Mark Heisler
Viking,Alberta Canada
Posted: 07/20/08 07:57am Link  |  Quote  |  Print  |  Notify Moderator
i had this happen to a friend and all it was was a bad ground.some trailer have fuseable links the resetable ones
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
Scarface56
Appleton, Wisconsin
Posted: 07/20/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Check the fuse (in fuse holder of the wire going to the motor for the legs)
Check Battery voltage
check ground wire going to motor for corrosion.
I had same problem and found the fuse in the fuse holder had some corrosion on it.
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
Radio
Middle of Georgia
Posted: 07/20/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same issue with a brand new 5th wheel.
Start at the switch that controls the up/down fuction of the jacks. Follow a heavy wire back to the battery box. Somewhere along there you will find a device that holds the fuse. It's futile to tell you what it looks like because thay are all different! Mine looked like an old fashioned flint and fluid cigarette lighter painted black. Yours will no doubt be different. But it will be between the switch and the battery.
Wade & Kathy
2007 F-150 XLT - 2008 Rockwood 8280SS
It's not the rig, it's where you go and who you go there with.
www.openroadsradio.net - For those who like amateur radio & RVing served up on the same plate!
weekendrvers
Iowa
Posted: 07/20/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Pat how did everything turn out for your friend?~~~Hopefully it was just the fuse and all is well with his Cougar~~Sandy
Coongoola
Australia
Posted: 07/21/08 02:38am Link  |  Quote  |  Print  |  Notify Moderator
Hey all,
Thanks for all the replies, I've forwarded them to Trevor over in Western Australia and at this stage I haven't heard back so hopefully he's up & running.
It's a near new Cougar that he's bought and also his first fiver. More & more people are seeing the benefits of 5ers over here finally.
Still many more "travel trailers" here, about 90% T/Trailers to 10% fivers.
Thanks
Pat
Dennis Bham
Alabama
Posted: 07/21/08 06:08am Link  |  Quote  |  Print  |  Notify Moderator
This is usually the fuse in the in-line holder near the battery. Of course it could be more serious, but look at the fuse first ...
If you over extend or retract the landing gear, it blows the fuse. I have done it myself a few times, plus the only time I took the trailer in for warranty work, the same fuse was blown by the repair shop ...
I now have an ample supply of proper fuses for the landing gear on board ... :-)
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
