RV.Net Open Roads Forum: Tech Issues: Replacing my Generator Propane Hose?
 > Replacing my Generator Propane Hose?
thefivers
LAS VEGAS
Posted: 07/19/08 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hello All, my generator propane hose cracked a while back and I need to replace it. I think I better replace both hoses coming from the large tank in my MH....I was wondering if I can buy the the local ( like camping world ) Has anyone had to replace their generator hose and any ideas for me. Can I just use Hose Clamps on it? The motorhome is a 1992 and due for hose changes anyway.
Thanks!
1992 Safari Ivory 36' Diesel Pusher 8.3L 4 Speed Allison
thomasinnv
where ever i stop
Posted: 07/19/08 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
absolutley do not use hose clamps. you can find different length propane hoses at most hardware stores, with the correct fittings on them. if needed you can also find an adapter fitting, but do not use hose clamps. i bought my propane hose for my generator at ace hardware.
1999 F-250 Extra Cab SD 4X4 V-10
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
robatthelake
Vancouver Island
Posted: 07/19/08 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
I second that!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
RJsfishin
Winston Or.
Posted: 07/20/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Why not ?
I been using worm clamps on barbed fittings along w/ fuel injection hose for propane for the last 14 yrs. Like I said before, I may not always know whats politicaly right, but I know what works.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
TEXAS
Centerville Tx
Posted: 07/20/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
If you are replacing the hose on the pressure side I would not use hose clamps. On the vapor side it would be ok. Most gensets only need 8-10 ounces to run. I think clamps on the pressure side on a motor home is asking for trouble.
jauguston
Bellingham, WA
Posted: 07/20/08 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about the big hose from the regulator to the carb? If so hose clamps are fine.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
hypoxia
Arizona
Posted: 07/20/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
If you can find some of THIS high pressure hose and THESE high pressure connectors, you can cut the hose to length and put the fittings on yourself easily. Those fittings are reusable and the hose will last forever unlike the hose that comes with most campers.
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
1990 Collins 24' 5th Wheel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
thefivers
LAS VEGAS
Posted: 07/20/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking for the hose that comes off the 100 pound propane tank and leads back to the generator. Is it a High pressure hose or just a standard hose?
I believe without going out to look I have two hoses coming off the tank. One heads to the generator. The other must be the stove, refer, etc.
I live in Henderson Nevada and hoping to buy it all local.
* This post was last edited 07/20/08 05:23pm by thefivers *   View edit history
hypoxia
Arizona
Posted: 07/20/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the generator hose. If it comes after the regulator it is low pressure, if it comes off between the tank and the regulator it is high pressure.
Wherever I happen to park
Posted: 07/20/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
As someone else said, DO NOT USE HOSE CLAMPS You want it done right,, A mistake, even a small leak.. And you might well wake up 2 counties over from where you parked your rig.
Camping world.. Your RV dealer A Propane dealer (NOT a fill-station but a real propane dealer, the kind that fills the tank at the filling station)
NOTE the hose for the generator may be carrying LIQUID propane, the other hose is vapor (ideally)
