RV.Net Open Roads Forum: How do you carry your blue tank
 > How do you carry your blue tank
darbyjudy
New Port Richey
Posted: 07/20/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I have a Class A Motor Home and I carry my ladder on the ladder that is on the motor home because I need it to reach the awning knobs when I deploy the main awning. I measured all of the compartments and none is large enough to carry the blue tank. I have thought of putting it between the rails of the frame where the spare tire is normally carried but the MH being so low it would be a bear to get it out each time I need to use it. How do the rest of you carry your blue tank? I have been carrying it in the toad but don't really like carrying it there. Any good suggestions.
2004 Gulf Stream 36 ft Sun Voyager triple slide
Workhorse W22 8.1
2004 Saturn VUE w/stowmaster towbar
Two Ole Pharts & One Little Shin Tzu named Isabel
Don Don
Pleasant Grove, AL
Posted: 07/20/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Why do I need a blue tank?
nelson
Clio,Mi USA
Posted: 07/20/08 11:02am Link  |  Quote  |  Print  |  Notify Moderator
I have one in one of the bays on the drivers side. Never had a reason to use it though. If I take it out, wife will just find one more thing we need.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
Tinstar
McKinney, TX
Posted: 07/20/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Strap it to the ladder in addition to your extra ladder. It's not heavy and I would think it would work.
I carry mine in a bay.
For Don Don, a blue tank is a portable tank that you can used to empty your gray and or black water from the coach when you don't want to break camp to drive to a dump station.
Never pass up a chance to go somewhere
henchman
Cardinal, Ontario
Posted: 07/20/08 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
You could tow it behind the motorhome, of if you have a toad, just double tow!
1991 Winnebago Warrior 30eu
OLD RIG
2006 Chevy Uplander 3.5l
2005 Jayco Sport 165 18' 3500lbs loaded
Putnam WD w/800lb bars
Acar friction type sway control
Hoppy digital display brake control
BALANCED tires! (Please everyone, balance your tires!)
flhtci-rider
Montreal, Canada
Posted: 07/20/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
had a Neptune with space between the 2 rails from underneath. I made an aluminium box for it and hung it from the rails. worked great. now the basement leaves no under place cause I do not want it in a bay so I cheat. It is in the trailer
2006 Scepter
2008 24' Haulmark EDGE
2003 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Genni
riggarob
Farmington, NH
Posted: 07/20/08 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
In my '07 FW Southwind, I took off the wheels and managed to get it into a compartment (I made the wheels into a quick disconnect affair w/ drilled axles, and pins). On the new Providence, it fits into the pass-through compartment. Mine is the 18 gal version. Robbie
08 Fleetwood Providence 40X
FL-XC
US Gear Braking system
Blue OX towing system
06 Saturn Vue AWD toad
Wife and best friend Martha Baby
SweetPea - 15 year old "Maine coon cat" still mean as ever
Beware of those who point their finger the LOUDEST !
Vettejim
N.W. Indiana
Posted: 07/20/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is in the shed behind my garage. I put it there right after I bought it about 8 or 9 years ago, I guess it was something else I didn't need.
2006 American Eagle 40J TS
2006 Grand Cherokee Limited 4X4, Hemi
2003 Dakota 4X4
2000 Corvette on a Bri-Mar trailer
Ruby & Willy, the Cavalier King Charles Spaniels
tropical36
Southwest Florida_USA
Posted: 07/20/08 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Try one of these for carrying extra gear and hitch mount it on the coach or the toad.
http://www.campingworld.com/shopping/item/widebody-hitch-haul/27596
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis
Diplomat Don
Moorpark, Ca
Posted: 07/20/08 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
darbyjudy.....Look in the area of your propane tank and see if it can be slipped above it. On my coach, I was able to hide it above the fuel tank.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
