RV.Net Open Roads Forum: Class C Motorhomes: Quick connectors on water hose?
 > Quick connectors on water hose?
Alpha Dog
Middle Tennessee
Posted: 07/20/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone here use those quick connect fittings on your drinking water hose?
If you do...plastic kind?...brass kind?
Do they leak?
Do you use them on both ends? (At the faucet and at the MH, or regulator on the way to the MH)
"Arvey" (yes, we gave him a name.)
2007 Coachmen Freelander 3150SS (32' class C)
My "kids" (a bunch of Toy Fox Terriers)
Backup Camera System from www.rearviewsystems.com
Frank's Electronics Voltage Booster (Autoformer)
ScanGauge II
GEO method
JOMO
Posted: 07/20/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
We use the metal kind and only on the MH, not the faucet. We love it, without it it was a pain to hook up with out a drip. Very quick hook up!
Beverley&Ken
Tottenham,Ontario
Posted: 07/20/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with JOMO, use a brass set at the MH end only, it has virtually eliminated any leaking, it is much easier to make tight connections each time you hookup.
Ken
Prin
Central Ohio, USA
We use the plastic ones and love them.
Ted and Carol
2008 Cameo RE373S
Chevy Silverado 2500 HD Diesel
Goldwing Motorcycle
Four Winns Boat
Z3 BMW
skipnchar
Topeka Kansas USA
Posted: 07/20/08 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
My "quick connect" just screws onto the hose connection. Takes about 5 seconds to connect. If it was any quicker I'd have to find something else to occupy my time better
Kamphiker
South Florida (this 'aint paridise anymore)
Posted: 07/21/08 05:08am Link  |  Quote  |  Print  |  Notify Moderator
I use them everplace at Home on all of the exterior hose bibs, Hose reels, Spray nozzles. Plus Use them on my RV hose and pressure regulator. Just makes life so much easier.
Mine are all brass with stainless steel locking balls. You can purchase from any industrial hose shop. They are made / distributed by mfg. such as Dixon / perfecting and Parker
Dixon part# DGH7 (complete set)
DGH7P (plug only)
DGH7C (Coupler only)
Quick coupler
bgie
MA
Posted: 07/21/08 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I use brass quick connectors anywhere I have a hose connections. I think they are great until the washer wears out. I have not found good replacement washers without paying a premium price. Fortunately the washers usually last for years.
I use a brass Y at the faucet with two Q-Cs attached, one for the water supply and one for an extra hose to rinse fishing rods, dog, etc. I think I have only left one set-up behind on breaking camp, education is expensive.
I tried plastic but found they don't last, brass seems much better. Leaks are not a problem as long as all is tight.
The issue of the diameter of the valve on the brass Y has been mentioned, it does reduce water volume somewhat but that is not a bad thing in an RV.
Bill
Bill and Karen
Chloe, the Golden Retriever
2006 Jayco Seneca HG33SS
Prin
Central Ohio, USA
Posted: 07/21/08 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Where do you get the brass connectors? When I got mine, they only had plastic, but brass seems like a better idea.
Kamphiker
Posted: 07/21/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Try Here:
Tampa Rubber & Gasket Co.
And look for more similar locations here: Rubber & Gasket stores in the USA
Jordan_and_Bev
Greenland, NH, USA
Posted: 07/22/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
We use the plastic ones from Camping World. They're on all hoses, filters, motorhome connections. To connect to campground fauset I screw on the snap-on first, much easier than man-handleing the whole hose, filters and pressure regulator. We have short, medium and long connection hoses all equipped with snap-ons, using whatever is appropiate for a given situation. Jordan
Jordan and Bev Spofford
Greenland, NH
2005 Born Free 26' RSB
1995 Suzuki 4WD Toad
