iam1ru12
Raleigh/Durham, NC
I've got two of the standard, white, bunk-end light/fan combos that plug into the ceiling lights.
However I've noticed if I keep the fan on high from more than 10 mins it starts to slow down to a speed even slower than the 'slow' setting. However, unplugging the mono-connection and pulling it back in speeds it up again but only for a short while. I however cannot replicate the slow down when using the low setting. Any thounghts?
Is this a fan problem or a power/wiring issue? I have not noticed any other drops in power.
-Mike
1999 Honda CR-V EX (his)
2004 Honda Pilot EX-L RES (hers)
2008 Rockwood 2302 Premier (pop-up)
2007 - Days Camping (Tent): 2
2008 - Days Camping (PopUp): 13
Camping Pictures
States Camped In:
mike4947
N. Syracuse, NY
It may be just the duty cycle of the fan. Some aren't designed to run at full speed continuously. But the first thing I'd do is check the voltage at the fan.
See if turning the light on on the unit OR the light it's plugged into shortens the time the fan runs full speed or draws it down immediately.
The 1/4" plugs are only rated for 4 amps and I'm not sure what draw the fan and/or the light in it has.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
nny12972
NY
Sounds more to me like you have a mighty weak battery and/or a low-power output converter.
J
iam1ru12
Raleigh/Durham, NC
nny12972 wrote: Sounds more to me like you have a mighty weak battery and/or a low-power output converter.
J
For the most part we're always connected to shore power. I am concerned about the quality of the converter. I'll have to snap so pictures and pull some specs.
Thanks!
-Mike
nny12972
NY
Mike....even though you're connected to shore power, if your battery is sucking most of the juice from the converter (which is minimal on most OEM converters), the symptoms I mentioned are very likely the cause----if that battery is done in, you could have a reasonably good converter that would exhibit exactly the problem you described....check the battery condition!
J
retiredtraveler
Woodstock Il --- GO HIKING!!!!
Are you sure the shore power was ok? I had this problem, only once, at once CG. It was going on for a couple of days there. Never experienced it again.
Pup: 2007 Jayco 1206 w/slide-out + shower
surge brakes, 54w solar panel
TV: 2005 Nissan Xterra 4X4, manual trans
25 years tent camping, 4000+ miles of hiking, lots of biking
campsite1
Orangeville Ontario Canada
I'm having the exact problem with my fan as well. I have three identical fans(as the ones that were posted) and only one is doing it. I'm guessing we have defective fans that seem to overheat or something.
daystrom
NE Ohio
My fans do the same thing except on the low setting. They may run all night fine. Other times they'll run for 15 minutes and then slow down to a stop. Turning them back on high for a second and then back to low usually fixes it for a while.
Power never drops, lights never dim. My take is they are junk. I may put a drop of light oil to see if that makes them spin easier.
2005 Dodge Ram 1500 QC 4x4
2005 Jayco Select 12HW
Nights camped in 2008: 21
Lots of camping photos
jimgoss
Northbridge
I made my own fans, without a light though. I bought 2 12V clamp on fans ($8.62ea) at Wal-Mart, cut off the 12v plugs and installed 1/4" mono jacks (Radio Shack, 2 for 3.99)and the things work great. They clamp to my center pole, although they seem to vibrate a lot, with the mattress on it just adds to the white noise effect to lull me to sleep. These fans oscillate too.
NFD.E-4 LT. JAG
2005 Jeep GR Cherokee LTD
Factory Tow Pkg.
Blue OX WD + Sway Ctrl.
Starcraft Travelstar 21SB
Wife, 2 kids and American Eskimo Dog
iam1ru12
Raleigh/Durham, NC
jimgoss wrote: I made my own fans, without a light though. I bought 2 12V clamp on fans ($8.62ea) at Wal-Mart, cut off the 12v plugs and installed 1/4" mono jacks (Radio Shack, 2 for 3.99)and the things work great. They clamp to my center pole, although they seem to vibrate a lot, with the mattress on it just adds to the white noise effect to lull me to sleep. These fans oscillate too.
Do you have any pictures?
