RV.Net Open Roads Forum: Fifth-Wheels: costly mistake. 5 wheelers please read.
 > costly mistake. 5 wheelers please read.
Page of 7
NavyDood
DFW
Posted: 07/21/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Penhall wrote:
chrizg wrote:
NavyDood wrote:
Isn't there a pin to lock the hitch handle that can only be pinned if the pin box and hitch are fully coupled?
Thats only on a B&W (that I know of). The B&W is either closed or open (Which is very nice)
The other hitches stay closed all the time but will let the trailer connect when backing in. The only time its supposed to open is if the pin is pulled to release it.
Surprised me when he said he had a Hijacker hitch - the pin won't go in until the bar is right across and hitched.
That is why I asked. I have the B&W w/Companion. If my handle is pinned, the only way the 5vr is coming unhitched is if the head assy and jaws completely fail or the pin on the pin box fails.
- 2004 2500 QC Short Bed, 4x4, 48re, Brite White, HOG 4" T-304 T-Back, Self made PSMBuick style intake, Isspro Pyro/Boost/Tranny Temp sittin on the dash
- 06 Pilgrim Legends 30RE2SLF-5 12,000lbs loaded
- B&W Hide-A-Ball w/5th wheel Companion
JCGibson
Anchorage, Alaska
Posted: 07/21/08 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Our hitch is a Valley hitch and you have to pull it open to back into it, then the latch comes around the pin and snaps into place. We then have a safety pin that goes in the pull handle to keep it secure. I thought I heard that Valley is part of B&W?
DH and I
2 teenagers
Buddy (dog) and Boo (cat)
'08 Dodge 3500 Megacab w/Cummins Diesel
'09 Heartland Big Horn 3400RE
Riever
Glendale, Arizona, USA
Posted: 07/21/08 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I'm still confused. We have a Reese 16K. When we back into the hitch jaws, the handle theoretically snaps into the closed position. We always make sure this has happened. Then, we close the safety latch, which can't be closed unless the handle is in the closed position. We then put a padlock through the safety latch to make sure it can't open and that some jokester can't open it when we're not around. I thought doing all this assured no accidental dropping of the 5th. wheel when we pull away. If one does this religiously, why should a test pull be necessary?? Thanks
Riever
davelinde
Freehold, New Jersey
Posted: 07/21/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Riever wrote:
Sorry, I'm still confused. We have a Reese 16K. When we back into the hitch jaws, the handle theoretically snaps into the closed position. We always make sure this has happened... If one does this religiously, why should a test pull be necessary?? Thanks
I also have a Reese 16K and watch the handle open and close, then lock it. I still visually inspect and pull test. In theory I've read the pin can "high hitch" and maybe mimic the open/close/lock of a proper hitch up. I like to think I'd see that too - hence the visual inspect. However, I've never seen it... so I pull test too. The risk is too great for me to deviate and what is the harm?
As I learned in my different "oops" the big thing is getting a routine that is rock solid and NEVER deviating from it. I will fix my tailgait eventually.... but for now I see it every day and am sick from being stooopid. A cheap lesson learned. I never want to drop a FW on my rails... but I'm not quite convinced I need the expense AND WEIGHT of a BS to prevent that.
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB
HO-CTD/48RE - Graphite: Raptor SS nerfs, Prodigy, Reese 16K Kwik-slide, BD X-Monitor, PML Trans pan, PML Diff cover, Firestone Airbags
09 Heartland Cyclone 3210
was_butnotnow
Fulltime: Emery, SD
Posted: 07/21/08 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
My hitch has a large long bar that has to slide between the pin and the mount. If the handle doesn't go all the way in I know it has not engaged.
Some hitches have a claw type of connection. Is that the problem the claw opens up and releases the hitch?
If I can see the handle goes all the way in and the BAR is ingaged I feel secure.
I'm not sure this thread isn't encourged by the company that makes the BedSaver.
NOW when my 5er drops down on my truck bed I will change my mind to be sure. And so sorry to you who have had that happen and when I see a bed in that condidtion I tear up.
See where we are at: DataStormUsers map
Sharing Travel Journals and Adventures Hitchitch.com
Personal site Fulltime.Hitchitch.com
jsinger
Bethlehem, Pa.
Posted: 07/21/08 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the accident...but no one was hurt! That's a good thing. In our case, losing a fresh water tank at 60 mph was a bit upsetting too, but again, no one was hurt. Regarding unhitching/hitching, I checked with Pullrite...they do not supply a piece of metal that would be designed to "catch" your 5th wheel. So, for 10 years(averaging 15 weekends a year)we carefully listen for the handle to snap the jaw around the pin. It has latched every single time. Thinking that the top part of my hitch was getting old('99), I sent it out to Pullrite this past Spring,and they completely refurbished it with a new jaw, new springs, and a brand new paint job...at absolutely no cost to me(only the shipping charges $28). I'm glad we went with Pullrite.
Best Wishes!
JB
dfb
gardnerville
Posted: 07/21/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have posted much earlier on this site that there are two types of 5ver owners, those who have and those who will drop their Rig on their truck... Even or Dealer did it on our new one....Bummer
luvglass
Milwaukee
Posted: 07/21/08 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
We have the Reese Signature 18K and there's a safety pin that wont go in unless you have a positive lock. It's worked for us for almost 3 years now. I look sometimes, but have never done the pull test.
What ever works for you.
Fred Wishnie
2006 Carriage Cameo 35KS3, 2006 Ford F350 diesel dually, fulltimer
See our blog at http://www.mytripjournal.com/wanderingwishnies
“If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got.”
hotrod4x5
Fulltiming Southwest USA
Posted: 07/22/08 12:31am Link  |  Quote  |  Print  |  Notify Moderator
Not usually. Those claws have the pivot point at the back, so when the trailer is pulling, they are actually pulling it closed, rather than trying to pull them open, as you might expect.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
pritch272
Martinez, GA
Posted: 07/22/08 02:14am Link  |  Quote  |  Print  |  Notify Moderator
That's what I thought with our Valley, that I had to pull it open to back into it, but that's not true (thanks to other members postings). So now, I just unlatch the handle and back into it, and it opens and snaps shut with a solid action. Sorry for the OP's misfortune.
Retired US Army
2000 Ford F250 SD 7.3 PSD, Firestone Ride-Rite™ air springs
2007 Keystone Laredo 29RL, Doran Pressure Pro and Metal Tire Valves, 16" Michelin XPS Ribs, Dirt Devil CV950 Central Vacuum, 2000W AllPower (Honda Clone), 4000/3500W Champion C46540
Page of 7
