mikhen
oley, pa
This one was in today's paper, close to home. Seems to happen a lot these days. I don't understand why they put a fire suppression in the engine compartments.
RV Fire
2002 Avalanche 2500
2006 Fleetwood Terry 300BH
Equal-i-zer
Tekonsha P3
Beer
outdoorsman2007
In the Woods - Somewhere!
Just an observation that most fires seem to be in motorhomes while on the road.
MudChucker
Winnipeg Manitoba
outdoorsman2007 wrote: Just an observation that most fires seem to be in motorhomes while on the road.
I've observed your observation quite a few times...maybe rolling with the propane valve on isnt such a great idea..not to say that having the valve on is the cause, but what you can do while the valve is on is the cause...
2006 Springdale 292BHLS
2007 GMC Sierra 2500HD SLT 6.0
Friendly Manitoba's ATV Community
www.atvpathfinders.net
donn0128
Pronounced Ore-gun
More likely the cause was from poor maintainece. I find that many people in all sorts of RV's buy them, park then for 50 weeks a year and then drive off expecting everything to be working correctly.
Donn
M GO BLUE
Southgate, MI
Read more closely...had nothing to do with the propane...Rv was acting up and stalled and when they opened up the engine hood a fire was there...
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS
Built-In Onan 5500W generator
okgc
southern Michigan
I found it interesting the owner called it a Winnebago when the back of the MH reads Pace Arrow. Wonder if it was 'borrowed'?
Suspect a 28 foot MH towing a enclosed car trailer might have been over weight.
Fleetwood Bounder 34J Chevy powered
Chevy HHR toad
Silverado 2500 4x4
Sundowner horse trailer
My hobby cars
1965 Chevy Impala SS 396
1964 Chevy Nova SS
itsalleasy
MudChucker wrote: outdoorsman2007 wrote: Just an observation that most fires seem to be in motorhomes while on the road.
If you observed most fires seem to be on the road and as the engine is a major source of heat and combustible fluids why do you then blame propane??
donn0128 wrote: More likely the cause was from poor maintainece. I find that many people in all sorts of RV's buy them, park then for 50 weeks a year and then drive off expecting everything to be working correctly.
So true. It was an older motor home, pulling a Camaro in an enclosed trailer, probably 5500-6000 lbs. Very likely over the capacity it is rated for, 90+ degrees according to an article about Sunday's weather, running bad before it stalled.
People think because these are big they will haul anything, if they only put a few thousand miles on them a year they only have to be maintained every few years. Bad mistake, because a vehicle that sits a lot needs more maintenance time than one that is driven daily.
psyflyjohn
San Diego, CA
Just finished installing a fire supression system in the engine compartment and generator - for about $350. Not bad price. Got the equipment at www.firefight1.com
I've read enough stories like this and seen too many burned spots on the road.
mockturtle
Northwest
okgc wrote: I found it interesting the owner called it a Winnebago when the back of the MH reads Pace Arrow. Wonder if it was 'borrowed'?
Or, it's a case of inaccurate reporting. It does happen.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
Yes - propane seems to not be involved in this one but the main point in having the propane OFF is to ensure that, if the fire reaches back and melts hoses/connections the situation is not made worse. It also protects fire fighters from potential explosion.
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2001 Silverado 2500HD shortbed
wonderful lifetime travelling companion/spouse
