RV.Net Open Roads Forum: Tech Issues: LP Alarm going off??
 > LP Alarm going off??
Katdaddy
Petal, MS USA
Posted: 07/21/08 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I received a recall letter on my fridge so I made an appointment to take it in this morning for the required fix. I turned off the fridge yesterday and also turned off the gas at the bottle. This morning when I went out to the camper the LP alarm was sounding. It stopped when I opened the door as the fresh air got into the camper. I checked and, yes the gas was off. A few minutes and the alarm goes off again. I again open the door, fresh air in camper and alarm stops. Just for the heck of it I turned the gas back on at the bottle and the alarm has not sounded again. All appliances were checked and are off. Any ideas on what happened??
Little by little, one travels far - J.R.R. Tolkien
There ain't no surer way to find out whether you like people or hate them than to travel with them. - Mark Twain
colochoclab
Arvada, Colorado
Posted: 07/21/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Bad LP alarm?
-Lab
2004 Nissan Titan SE Crew Off-Road & Big Tow, LT Tires
2006 Jayco JayFlight 29FBS
Equal-i-zer Hitch
Prodigy Brake Control
Member of clubtitan.org
"Hershey" the Chocolate Lab (Best Friend)
"I asked God for a true friend: He sent me a Labrador Retriever."
Clay L
Sioux Falls, South Dakota
Posted: 07/21/08 10:12am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of household cleaning and deodorizing products that will set the alarm off. Hairspray and the like will also set it off.
I also find that blowing it out with my compressor from time to time will help cut down on false alarms.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Pangaea Ron
Anacortes, WA, USA
Posted: 07/21/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Low battery level?
It's also been suggested here before that they have about a 5 year life span and need to be replaced?
2002 Triple E Senator 28C XL
w6pea
San Diego, Mexifornia
Posted: 07/21/08 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Make sure there is nothing in front of the LP monitor. I leaned a small folded table against the counter in front of ours last year and at midnight the alarm went off lifting us off the beds in fright.We looked all over the inside and opened the door and aired out the place. We went back to bed...about 10 minutes later the same thing happened, we were really worried. We started to look for the alarm monitor and that is when I noticed the table leaning against the sink counter. Our monitor was under the cupboard under the sink. I moved the table and no more alarm sounds. I never put anything anywhere near that thing again....can't take a chance on that happening too many times as I don't think our hearts could take the levitation abuse.
Evelyn, w6ome
"Without Truck Driver's America Stops!"
Beware of KQ Ranch/CRA Resorts
"Too late to save your shoes,roll up your pant legs!"
"I need more Coffee & Old Bushmills!"
"When all else fails, Ham Radio!"
"Semper Fi"
Wherever I happen to park
Posted: 07/21/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
First you really should not call it an "LP GAS" alarm
It is an "Explosive Gas" alarm. it can not distinguish between LP gas, Gasoline vapors, Alcohol vapors, Butane, Methane just about any---ANE, (Including propane, the P in LP) what it can not detect, since the L in LP means LIQUID, is LP cause LP is not a gas,
It can also detect water I found out the hard way
(Well water shorted it out and off it went)
However any explosive gas.. Some of these can be generated naturally (Methane for example) and thus there may have been no malfunction.
GATJcampers
CA
Posted: 07/23/08 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same when the trailer batteries are about to die. It lets me know its about to stop working.
Posted: 07/23/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Re. read the original post.... It may be that something tried to light and could not due to not enough pressure in the line.. THe remaining as in the line vented into the rig and set off the alarm. If this is the case the alarm worked as designed. however there was no real danger.. This is actually a good thing
