RV.Net Open Roads Forum: Tech Issues: Camper breaks work some times
 > Camper breaks work some times
RickyD32
Essex Jct., Vermont
Posted: 07/21/08 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Sprinter by Keystone, my breaks work great then there is no breaks. The break controller is a top of the line tekonsha p3. It's brand new. I got the folks at the camper place to replace the old one. Then I find out it is not the controller after all. I pulled one of the tires and checked the breaks. They seem fine with little to no wear. I have checked the connections I can get to and they look OK as well. Not sure what is going on here. I am assuming it is another lose connection some where but can not find it. Can you direct me to where it might be?
dbbls
Missouri
Posted: 07/21/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
The wire from one side of the axle to the other goes through the axle. This will wear through and short out. Replace it with one on the outside of the axle and I bet your brakes will work.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
tvman44
Southwest Louisiana
Posted: 07/21/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Look for those little press on splices some use for quick easy connections. They are nothing but trouble.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
RickyD32
Essex Jct., Vermont
Posted: 07/21/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys! I will look for both and try that. I have to say this is the most helpful forum I have ever seen! Thank you so much!
Rick
Retired Army SSG
Turner, Oregon
Posted: 07/21/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
oh I got it, it is a travel trailer, not a camper
garry1p
Broken Arrow, OK, USA
Posted: 07/22/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Most intermittent problems turn out to be the ground connection on the TV or RV and you end up trying to get the ground through the trailer ball.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Larry202br
Olathe, Ks
Posted: 08/25/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
The P3 has a troubleshooting mode that will indicate shorts, opens, open ground, as well as voltages and currents. Using the troubleshooting mode as explained in the manual will find your problem for you.
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
