I know that this has been cussed and discussed, but I cnanot find the post that talked about "303 protectant" for UV protection for the tires. Can someone fill me in?
Thanks
Whenever you wash your vehicle, you should clean the tires too. If you do need to put something on the tires, use the ones you apply by hand. I find them to last a lot longer than the ones you just spray on.
Most mfrs tell you to clean 'em and leave 'em - no 'so called' protectant should be applied. There is a mystery liquid inside the rubber, and the rolling action of the tire 'pumps' this liquid from the inner walls thru the sidewall and onto the exterior surface, where it protects the tire fron ozone and other bad things. Anything that interferes with this action is bad bad. I know, a zillion guys have been armor-alling thier tires since the civil war - tell it to BFG, et al.
Joe
