RV.Net Open Roads Forum: Tech Issues: leak in fresh water system?
 > leak in fresh water system?
Jaseun
Annapolis
Posted: 07/21/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have noticed that my Lance 815 water system has maybe developed a leak on the pressure side. The symptom is this, when I turn the fresh water pump on, and all taps are closed tight it will pulse every 30 seconds or so. I can not find any leaks anywhere. I have really gone over the camper thoroughly. I have only two sinks, toilet, outdoor shower and drains.
At the same time I noticed that when I turn the water on very low volume that the pump cycles quickly, about five times more often then it did before. An example is that I just use a tiny amount of water to rinse my hands and I do this often enough to notice this change in behavior.
My first guess is that the check valve in the pump is failing. Do you think I'm on to something? -Jason
dbbls
Missouri
Posted: 07/21/08 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
My guess would be the check valve.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
robatthelake
Vancouver Island
Posted: 07/21/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a Valve for filling the Tank while Hooked to City water You should Take it apart and replace the washer/O ring! The symptoms You are describing sound like what I had! The solution was a new O Ring!
If you don't have that Valve My solution won't do you much good!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
Dave H M
IL
Posted: 07/21/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
that is what the cause was for me - check valve. If you have a persistent leak it will show up somewhere. I would check visible areas though.
Kendas
Tucson AZ
Posted: 07/21/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Also check you low point drain valves. They don't get used much and don't always close all the way when you de-winterize. make sure that you have them closed firmly.
1978 21ft Tioga Dodge 440 Motor.
Misc Things I've done to my RV pictures
USAF Retired
To Err is human... To Forgive is not SAC Policy.
Jaseun
Annapolis
Posted: 07/22/08 05:40am Link  |  Quote  |  Print  |  Notify Moderator
I don't have a city water fill valve in my system. I have also checked all of the drains. The unit is a 2003 so warranty is of no issue at this point. Guess I should take the pump out and have a look see. I have been meaning to install a pressure tank anyways. Thanks for the help. -Jason
sum1
So-Cal
Posted: 07/22/08 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Also possible internal leak in pump
