hlbly
Buena Park, CA
I have been looking at several different types of motorcycle chocks, baxley, la chock, and came across this one today and wondered if anyone has or knows someone who has one and if they are happy with it? I will be using it on a road glide. Thanks in advance for the info.
06 KFX 400
06 KFX 400
06 KFX 400
06 TRX 90
06 HD Road Glide
00 F350 PSD 4X4 CC SRW Banks Big Hoss, Air Cleaner, Exhaust, Gauges & Trans Command
Gearbox 335FS
Ride Rite air bags
DJF
Simi Valley Ca
I have Bike Pro in my trailer and have been across the USA 4 times with an Electra Glide.My trips last approx 8 months and i use the bike every day.I only strap the bike down when im rolling, At night i use the trailer as a garage and merely drive it into the rack. It holds just fine.
My brother has the Condor in his trailer. Im sure they are all good. Just be sure and use the BIG rachet strap's. The dirt bike strap's wont pull down enough.
Also because you have a big touring bike,I wielded a plate under the trailer to the frame and bolted thru that. Then to be safe i took out the two bolts that came with the chocks,(Grade 8)and replaced them with grade 10's. Im not sure that's needed.
Good Luck
DJ
rdam
Lake City, Florida
Bike-Pro. Many thousand miles with an ElectraGlide and Sportster with no problems.
2006 Weekend Warrior LE 3505
2004 Ford F-250 Supercab 6.0L Diesel/Auto
hlbly
Buena Park, CA
those look good but i don't want to drill any holes in floor of trailer, which is why i was looking at this one.
BigG-Samm
Lake Conroe, TX
I bought the Baxley 4 years ago for my Softail Heritage, it's a little more but has never given me a problem and I've used it in the gargae everyday and in my TH when traveling. Good luck.
Big G & Samm
'06 KR F250 PSD 4X4
'09 Razor 3110
'05 HD Heritage Classic
flhtse05
Pace, Florida
I have had the Baxley since 2000 and no problems.
DJF
Simi Valley Ca
I just went to the Baxley web site and see they offer the bolt down kit for trailer use.
Are you guys using the Baxley without bolting it down? If so does it hold the big bikes,without moving around.
Tks
DJ
DCDOC
Manteca, Ca.
I purchased a wheel chock that looks very much like the bike pro from Harbor Tools for 39.95 last month. I use it for my road glide and it works great!
04 Dodge CTD towing a Ragen 3005
rdam
Lake City, Florida
I would be real careful about putting a $20,000, 850 pound Road Glide in a chock that was NOT secured to the floor. On a real bumpy road, or speed bump, its very likey to shift...Iv'e seen it on a friends trailer.
The Bike Pro...and similar models, have a quick detach feature which leaves the floor clear. They are really worth the $$$ and once you use one, you'll never go back.
miken807
Dover, DE
I just ordered one from Harbor Freight, it is on back order until Oct.
