RV.Net Open Roads Forum: Folding Trailers: Running lights not working...
 > Running lights not working...
habsfan
New Brunswick, Canada
Posted: 07/21/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hi...
All of a sudden my running lights on mu PUP will not work when I have the headlights or parklights turned on in my TV. They will however come on when I press the brake pedal and when I turn my right turn signal on... Help!
1 Wife (age not to be disclosed)
+ 2 Daughters (ages 6 and 8)
+ 1 - 1998 Bonair 800XL
+ 1 - 2004 Dodge Caravan SXT
= Loads of fun camping!!!!
mike4947
N. Syracuse, NY
Posted: 07/21/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Time to clean out & inspect the connector. In most cases corrosion in the TV end is the cause. The poor connector sits there under the TV 24/7/365 without a thought collecting all the rain/snow/crud/dirt from the road.
A good cleaning with contact cleaner available at most auto parts stores and Radio Shacks is a good start. If that doesn't fix it it's time to check for loose wire connections in the plugs.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
habsfan
Posted: 07/21/08 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Mike,
They were working fine until I was over at my father's house and he decided that the terminals looked dirty and dressed them with some kind of contact cleaner/paste that is supposed to make a better contact by cleaning it... Not sure what happend there...
mike4947
N. Syracuse, NY
Posted: 07/21/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a case of if a little is good a lot is better..LOL. The contact cleaner we use comes in a spray can. The paste types can easily short out between the contacts in the plug. They are supposed to be applied using something like a cue tip and then cleaned off so the paste cleaner itself doesn't form an electrical path.
We also along with using the spray cleaner use dielectric grease to help prevent further corrosion between maintenance cycles.
sandmangw
Virginia
Posted: 07/22/08 07:31am Link  |  Quote  |  Print  |  Notify Moderator
methinks Mike4947 has hit the perverbial nail on the head!
DIMDave
Sachse, TX
Posted: 07/22/08 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
If the running lights come on with the brakes, you're missing the ground. Clean the connector and try again, then look for wires pulled loose in the housing or under the vehicles.
(24/7/*52* or 24/365)
97 Sun-Lite Eagle RK
01 F250 CC SWB PSD
habsfan
Posted: 07/22/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Is the trailer grounded through the hitch? Or is it a seperate connection on the wire harness... I think somebody once told me that it was the white wire?
mike4947
N. Syracuse, NY
Posted: 07/22/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Here's links to the pinouts in connectors. There is always a ground wire pin.
http://www.rverscorner.com/wiring/index.html
http://www.accessconnect.com/trailer_wiring_diagram.htm
