RV.Net Open Roads Forum: Folding Trailers: Cleaning mildew off of inside of PUP
 > Cleaning mildew off of inside of PUP
habsfan
New Brunswick, Canada
Posted: 07/21/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hi...
Has anyone tried Armor All Oxi MAgic Carpet and Upholstery cleaner to clean mildew off the inside of their PUP? It works great on my carpet and seats in my car... I just tried a spot and it worked quite well, but I'm not sure if I should try it everywhere... Its active ingredients are hydrogen peroxide and isopropyl alcohol. I was unsure about using bleach... Any thoughts...
1 Wife (age not to be disclosed)
+ 2 Daughters (ages 6 and 8)
+ 1 - 1998 Bonair 800XL
+ 1 - 2004 Dodge Caravan SXT
= Loads of fun camping!!!!
gr-racing
N.E. Ohio
Posted: 07/21/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
When I was still a boater we used a bleach/water mixture on all surfaces of the boat. Many are the same as my pup including the ceilings
Dave Rolling
2004 Chevy 1500 Silverado.
2006 Fleetwood E2
jmcnab
Toronto Ontario Canada
Posted: 07/21/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
we've used Star Brite mildew cleaner for years on our boat and RV and love it.
click here for link to product
02 Yukon Denali XL
08 KZ Spree 324BHS
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 07/21/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
SunBrella (Fleetwood/Coleman) and CamperTex (Jayco) and other fabric/vinyl tent manufacturers have their own set of cleaning instructions. Using the wrong stuff can cause it to loose it's water repellant coating, or damage it.
gr-racing
N.E. Ohio
Posted: 07/21/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking of the hard parts of the PUP. On the canvases you need to use a soft fabric type cleaner that the manufactur recomments.
jspringator
Versailles, KY 40383
Posted: 07/21/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Walmart and West Marine sell Spray 9 cleaner that will remove mildew without damage to the surface.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion LTD 3.73 LSD, V-10, 2WD
Yamaha EF2800i genset;
2000 watt Tripp-Lite inverter/charger APS 2012
12' Porta-Bote 75 6 hp Johnson
1989 Bayliner Ciera 2150
Saturn SD365 inflatable, 75 Rude 25HP
habsfan
Posted: 07/22/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I called the Clorox company that makes Armor All Oxi Magic Carpet and Upholstery cleaner and they told me that it will be safe for the fabric in my PUP, but that it is NOT a disinfectant, therefore will not get rid of mildew... But it did do a good job cleaning up the black stains i had on the inside of my bunks...
4hapyMcDs
Southern Ont. Canada
Posted: 07/22/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
We used bleach and dawn dish liquid, take a little scrub brush. We took the mattress out and laid a tarp down just in case. Then you will have to spray with 3M scotch guard. You spray the inside of the PUP, Yes inside. 1st time we sprayed outside did not work, I called the dealer and they said inside only. It worked great after that.
The outdoors is a wonderful place to be....
