RV.Net Open Roads Forum: Tech Issues: Acme nut on Propane tank pigtail
 > Acme nut on Propane tank pigtail
FB1965
East Tennessee
Posted: 07/21/08 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone ever had a Acme nut start leaking on a propane tank pigtail?I have one that is leaking when you move the hose the least amount.I checked the threads and all looks good.Thanks
hotbyte
Barnesville GA
Posted: 07/21/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Had one start leaking on our home grill. Never could get it to stop even moving hose around. I had an extra Acme nut where I'd changed over some fish cookers to POL because of setup at football field concession stand. The new one didn't leak so I chunked the leaky one.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
Larry & Linda
Lansing MI/????
Posted: 07/22/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
it,s not the thread that is the problem. There is a brass seat or a rubber seal inside that is not sealing.
Larry
RJsfishin
Winston Or.
Posted: 07/22/08 07:44am Link  |  Quote  |  Print  |  Notify Moderator
It could be the nut,....as the nut-seat could be damaged. Otherwise it would be a defective seal/plunger conglomeration that is inside the OPD tank valves. If that is the case, the valve has to be replaced, because the parts inside are not servicable.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
