My HWH levelers move in pairs; 2 front or 2 right or two left or 2 rear. If you have air ride, dump the air first, then level front to back, and then side to side. I bought one of those leveling gadgets from RV Innovations and it works great. CW sells them now for about $45.00.
Also, leave the bathroom door about 1/2 way open. When it stays open you're very close to level.
Usually the Legos will get crushed by the weight of the m/h. A piece of plywood works good or cutting boards from WM.
Doug and Cassi Glass wrote: My HWH levelers move in pairs; 2 front or 2 right or two left or 2 rear. If you have air ride, dump the air first, then level front to back, and then side to side. I bought one of those leveling gadgets from RV Innovations and it works great. CW sells them now for about $45.00.
I had a 2x10 plank that I used for ramping and leveling my old A that didn't have levelers. I cut it into 10 inch squares and was using them for landing pads beneath the levelers until they started to break one at a time. Now I use nothing under the levelers feet.
Quote: leave the bathroom door about 1/2 way open. When it stays open you're very close to level
The MH could lay on its side and if I opened the bathroom door it would stay where I put it. That is an exaggeration of course, but the hinges on the bathroom door are stiff.
