RV.Net Open Roads Forum: Tech Issues: puzzling shower problem
 > puzzling shower problem
camperdave
northern, California
Posted: 07/21/08 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a shower problem I cannot figure out. If I turn on the Hot water valve in the shower, nothing happens. No water comes out the head. If I turn off the Hot, and turn on the Cold, cold water comes out the shower head at a normal flow rate. Then, if I leave the Cold valve on, and open the Hot valve, I will now get some hot water flow along with the cold. If I then turn off the Cold valve, the hot will flow, though at a significantly reduced rate from what the cold flows, and sometimes will stop altogether. Sometimes I cannot get the hot to flow at all, even with the Cold valve open.
It's always done this to some extent, but seems to be getting worse. Had to take cold showers last week!!
All of this is working off the onboard tank and pump, but it doesn't seem like a pump problem to me since the Cold side works just fine. Any thoughts or things to check on?
btw, all other faucets in the trailer work just fine with Hot or Cold water, including the exterior shower.
Thanks,
dave
Rvndave
Medina, Ohio
Posted: 07/22/08 12:07am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a shower faucet problem to me. I would try to replace the valve seat if possible, if not the whole faucet.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
Magician
Belleville, ON
Posted: 07/22/08 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Your problem is very likely in the faucet itself. You didn't say, but I assume you have good hot water flow from other faucets eliminating things like malfunctioning back flow check valve on the water heater itself. You weren't specific about the type of faucet but I assume from what you said, you have individual hot and cold water valves, not a mixing valve. If this is the case, faucets are inexpensive and a simple frustration free fix would be to replace the faucet. Otherwise, I'd take it apart to diagnose the problem.
Magician
MCP, IEEE, CCP, BJCP
Traveling, Working, and Judging
camperdave
Posted: 07/22/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Yes, the hot works fine everywhere else, and it is the typical dual handle plastic RV shower faucet. I'll pull the faucet today and see what I can find.
camperdave
Posted: 07/22/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
problem fixed, it was indeed the faucet itself. The seat on the hot side had come apart (it's a cheapo little plastic snap fit type deal) and was not being pulled back when the handle was turned. I guess sometimes the water would push through a little bit, but not always. I feel a bit silly that it was such an obvious and simple fix, but glad it's fixed!
Rvndave
Medina, Ohio
Posted: 07/22/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for letting us know what you found.
