Mike & Les
Caldwel, ID, USA
I’m getting ready to have power run out to our motor home but I’m not sure what I need. When I get bids I want to make sure they are all bidding on what I need and not taking short cuts to low-ball the bid.
We have conduit running to our pad which is about 50’ from our house. The main panel is on the other side of the house so that would be another 50’ to 60’for a total of 100’to110’.
I want a 30 amp circuit and a 20 amp circuit installed.
Do I need one set of wires for each circuit?
What gauge of wire do I need installed?
Any other specific things do I need included in the bid?
Any advice will be greatly accepted.
Thanks,
Mike
97 Bounder (F-53)w/Banks
Toad: 03 Ford Explorer
crankshop1000
se michigan
It may not be possible to get the right answer here due to codes and local ordinances.There are a few different ways to get what you want, but since you are contracting the work out you will be dealing with a permit, licensed electrician and inspections.Most likely scenario is a new metered service will be required.
craig7h
Marion, Iowa
try this link
http://www.myrv.us/electric/
Craig
06 RAM 3500 diesel power
08 35' Cardinal
Chris Bryant
DeLand, Florida, USA
As long as you are running it, I would spend a bit more and run a 50 amp circuit out, then put a sub panel to get 50, 30 and 20 outlets.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
ShapeShifter
Buffalo, NY
Chris Bryant wrote: As long as you are running it, I would spend a bit more and run a 50 amp circuit out, then put a sub panel to get 50, 30 and 20 outlets.
I would do the same, with the "sub panel" being one of the typical campground pedestals with those three outlets and the associated breakers.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
hypoxia
Arizona
Ditto, Chris always has advice worth listening to.
Power Panels
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
1990 Collins 24' 5th Wheel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
Dave H M
IL
Do the sub panel
Now on the codes, meters, and so on.
I live in the country and you don't need any of that. The power company does not have a problem if you take the power after it goes thru the incoming meter. If you have to pay for all the stuff coming in thru the main meter why do a separate meter if you are not gonna charge for the site?
donn0128
Pronounced Ore-gun
Any licensed contractor will by law wire to NEC and local codes. All you need to do is tell them exactly what you want. Putting the box out on the RV pad is a good idea. That way you can have any and all powers available should you desire to hook up another RV in the future that does have 50 amps service.
Donn
RJsfishin
Winston Or.
Run # 6 x 4 wires to a sub. Then pull a 30 amp receptical w/ breaker, and a 20 ampreceptical w/ breaker. Its not science !
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
Delaine and Lindy
Linden Tn. (The View)
Go with a 50 amp!!!!! I have been there and done that twice. Its not really that much more expensive. Almost any Lic Electriction will be able to do the job, after you tell them what you want. I think it cost me around $200.00. Good Luck... GBY....
2008 Chevy Silverado LTZ 3500, DRW
2008 Chevy Equinox LTZ
2009 Mobile Suites 36TK 3
B&W Hitch
www.webspawner.com/users/lnhdch
We are Blessed !!!!!!
