kwilkins
Media, PA
I’m researching RV’s and am considering both a Class A and Class C. Two main requirements I have are to keep the length to 32 feet or less (less is better) and to be able to sleep 4 adults comfortably. With the Class C the cab over bunks are large enough for two adults, although I guess climbing up and down is not much fun.
My question is are there any Class A models 32 feet or less that will sleep 4 adults comfortably. I’ve seen some dinettes and sofas that convert to beds that would work for kids, but are too short or narrow for two adults.
Thanks for any advice you can offer.
Ken
mcewena
Canada
How about the Safari Simba: http://www.safarimotorcoaches.com/archive/2007/safari.aspx?content=index&model=simbasve
tatest
Oklahoma
There are models with sofas that convert to usable adult beds. Take a look at Winnebago's Rest Easy (tm) sofa. It is not available in entry models, but I know it is available in the Voyage, which as recently as 2005 had a 31' rear bedroom floorplan.
Other manufacturers should have something similar. Not everyone offers only the jack knife sofa. Most offer something at least like a residential hide-a-bed (probably also a trademark), if they have a living room slide that gives it room to pull out.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
winfan
Check this one out. It is a Rexhall S300/L300. It is about 1 foot bigger then you might be looking for. Pretty sharp unit. http://avwebmaker.hypermart.net/rexhall/features3.html#l300
Warren, Mary, Chris (#3 and last) and Sonny the Border Terrier
2002 Rexhall Aerbus 3550BGS
FMCA 388864
Bumpyroad
Virginia
the only sofa that converts to a sleepable bed is a magic sofa bed from Bradd and Hall. certainly no standard jack knife will work, and any cheap sofa bed will need additional "help".
bumpy
SCHARLEY
Atlanta, GA
Sounds like a class C would fit your needs better to me.
SCHARLEY
kwilkins
Media, PA
Bumpyroad wrote: the only sofa that converts to a sleepable bed is a magic sofa bed from Bradd and Hall. certainly no standard jack knife will work, and any cheap sofa bed will need additional "help".
bumpy
Thanks for the info.
Are there RV manufacturers who use the magic sofa bed from Bradd and Hall in their small Class RV's?
D.R.Bain
Michigan
kwilkins wrote: I’m researching RV’s and am considering both a Class A and Class C. Two main requirements I have are to keep the length to 32 feet or less (less is better) and to be able to sleep 4 adults comfortably. With the Class C the cab over bunks are large enough for two adults, although I guess climbing up and down is not much fun.
Ken
My F-I-L has a 19 foot Winnebago class A, that will sleep 6. It is on a Dodge Chassis with a 318 engine. Of course it is 33 years old, and still original interior. The paint is worn thin in some areas from The turtle waxing it got every year.
Dan, 2007 Damon Daybreak 3270
Bumpyroad
Virginia
kwilkins wrote: Bumpyroad wrote: the only sofa that converts to a sleepable bed is a magic sofa bed from Bradd and Hall. certainly no standard jack knife will work, and any cheap sofa bed will need additional "help".
bumpy
I think that Newmar offers a MSB.
bumpy
HobbyHauler
South of Nashville, TN
Class A: drinks 6, eats 4, sleeps 2
Les Stallings
2002 Monaco Dynasty Jack 38, ISL 400, TAG
Toad: 2003 Saturn LW300
