sumerduck8
Virginia
Need help! My cursor jumps around all the time. Example, when I type a e-mail the cursor will jump and start typing at another location, or when I am sending e-mails to a number of individual, I use the Bcc to hide each name, but the cursor will jump to the To: block. Is there anyway to fix this problem? Any help would be appreciate. Thanks...Your friend Houston
PopBeavers
San Jose, CA
I ahve had that problem for several years, intermittently, on WinXP, on some but not all of the computers I use.
I have never been able to figure it out. I am interested in any suggestions others might have.
Wayne in San Jose
2002 Chevy Silverado 1500HD 4x4 Crew Cab
2005 Trailmanor 2720
Valley Odyssey brake controller, Honda 2000 generator, McKesh mirrors
Yamaha WR250R, Polaris Sportsman 700 X2, Polaris Scrambler 500
1997 Dodge Dakota stick to tow the ATV trailer
troll3193
SouthWest, MI USA
desktop or laptop????
assuming laptop, happen to have a touchpad??? I have had a lot of issues with touchpads that support "tapping"...
Usually an advanced option to disable... Tapping is what let's you tap on the touchpad to "double-click"... Causes some of the issues you are talking about.
FWIW,
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
bcsdguy
California
You may have a bad keyboard. They don't last forever and they aren't so expensive you couldn't just replace it. If you have another one available, try typing with it. You can also plug an external keyboard into most laptops.
PopBeavers
San Jose, CA
Well, at least for my situation I don't think it is the keyboard. I say that because it most often happens in FireFox and I have never seen it at all in IE. Once it happens, it wanders around randomly even outside the firsfox window. It only happens for about 10 seconds, so there is no time to close FireFox to see if the problem goes away.
I have FireFox also installed on Win2k, and it never happens.
In my situation I think it is FireFox for WinXP that has the problem, but I can not prove that.
wilanddij
CA Desert
Have you tried a different mouse or a different mouse driver?
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
weasel4
Alberta
Go to the Mouse settings in Control Panel/Pointer Options and check if the Snap
To button is turned on.
BTC
sumerduck8
Virginia
I wish to thank everyone who responded!!!! wease14, you are the man! Following wease14 suggestion, here what I did....Control Panel, Mouse, Pointer Options, Snap To: check box....automatically move pointer to the default button in a dialog box....Now my cursor is stay put. Big thank you. Your friend Houston
Mandolin Guy
West Central Georgia
If you're using a ball-type mouse, you may need to clean the inside. The ball can be removed revealing some rollers inside. These will collect all kinds of dirt, grease, etc., and sometimes will not contact the ball so that it moves properly. An optical mouse will not have this problem.
If it's a touch pad, very dry fingertips may cause a problem. There must be a certain amount of conductance between the skin and the touchpad for it to work properly.
David
There are three kinds of people in this world: those who can count and those who can't.
Retired Cop, 31 years
