RV.Net Open Roads Forum: TV help - 5800 lb TT - looking for SUV
Search only in Towing
Open Roads Forum  >  Towing
 > TV help - 5800 lb TT - looking for SUV
doko
binghamton
Posted: 07/22/08 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Prospective Trailer is:
Forest River Salem 26TBSS
Hitch Weight - 805lb
Dry Ship Weight - 5880lb
GVWR - 7805lb
Looking for TV thats not diesel, not a flat bed.
Essentially looking for an SUV.
Assuming 1,000 lbs. stuff
400lbs of passengers
130lbs of dogs
water tank empty.
Fairly flat terrain.
Mainly a question of comfort in the drive and sway.
Not too worried about blasting up hills, just enough to get up the hills and not trash the TV
TIA
doko
kknowlton
Wisconsin Border Country, IL
Posted: 07/22/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
How long is the trailer? You'll need to keep wheelbase in mind too; I'd recommend the largest SUV you can find (Excursion/Suburban) because of that factor. Be aware that any options the dealer adds to the trailer will increase its base weight.
Be sure that any SUV you get has the heaviest-duty tow package available from the manufacturer, or it may not have the oomph to tow the trailer - at least not in a way that will make you happy.
MFinCA
San Francisco Bay Area, CA
Posted: 07/22/08 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
SUVs like the Chevolet Suburban or GMC Yukon XL. I'd opt for the 2500 model, as you are probably going to be towing about 7,000 lbs. fully loaded.
Another often forgotten tow vehicle is a full-size van. The 2500/3500 models make fine tow vehicles as well as people movers.
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
mikehart92
Oklahoma
Posted: 07/22/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto on the last two posted. 2500 or better. The rest you are just asking for trouble.
Mike
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
Cabriolet86
Rochester, MN
Posted: 07/22/08 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
You don't have a 5800 pound TT, you have a 7805 pound TT. Your trailer will definitely NOT be 5800 pounds loaded. You're probably looking at 7000 pounds loaded at a minimum.
A used Ford Excursion would be at the top of my list, but if you want new, I'd suggest the longer wheelbase Suburban/Yukons or longer wheelbase Expeditions (only the newer models were available with longer wheelbases). As the others have mentioned, the long wheelbase Suburbans and Yukons are available in 3/4 ton models, which would be ideal.
The short wheelbase Expedition, Tahoe, and Yukon might be rated nearly that high, but your stability won't be great.
doko
binghamton
Posted: 07/22/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
TT is 28'9"
So, your opinion would be that even with a Tow capacity of 8k, an expedition would not have the wheelbase or power to tow this TT comfortably --- correct??
the above comment mentions expedition -- presumably talking about the expedition EL ??
mikehart92
Oklahoma
Posted: 07/22/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
doko wrote:
TT is 28'9"
See my above answer.
Mike
Terryallan
NC
Posted: 07/22/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
doko wrote:
TT is 28'9"
An Expedition would be pretty close. Length would not be the problem. Expes are pretty stable. But, Even with a 8000lb tow cap. Once you subtract the weight of the family. That 530 lbs, you mentioned. You have only 7470lb tow cap left. So you have a 610lb cushon if you do in fact keep it to 1000lbs of cargo. Might be ok on the flats.
Will say. My 02 Expedition towed our 28' TT very well, with no sway at all. As stable as my 145" WB F150. But my TT isn't as heavy as yours
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
NHguy
NH
Posted: 07/22/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
You could also get a 3500 van to handle that heavy TT. Or a 25 to 3500 level 4 door truck. My truck is rated for over 8000 lbs, but by the time I load it up with kids, dog and firewood; I use up the gcwr and my real tow rating falls to 7200 lbs when the truck is at gvwr. Expeditions and Suburbans don't handle as much weight as trucks because they have more body and carried weight. See what the curb weight is on the prospective TV and add what you need to carry. From that you can work out tow vehicle GVW (actual weight) vs GVWR and see how much TT the TV can handle. Finds this by taking GCWR minus GVW of the tow vehicle.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
dlord
St Augustine, Florida
Posted: 07/23/08 05:57am Link  |  Quote  |  Print  |  Notify Moderator
There's a nice 2005 V-10 Excursion at Texas Direct Auto for around $13,000.
2003 Excursion Limited 4x4 V-10
2007 Rockwood 8318SS/Equalizer/Prodigy
