pointman77
Idaho
Just purchased a 93 fleetwood trailer.We had a very large rain storm today so i decided to check trailer for leaks. I discovered a decent leak coming in the ac panel. Its a Coleman model 7330-730, controlled by thermostat.I climbed up and looked to see just how tough it would be to repair, and i just cant see how to seal it up short of pulling ac unit off. I would really appreciate any advice.
chrisntims
West Virginia
Pull the inside panel off and look up in there. There should be 4 bolts or nuts. These are probably loose. Just tighten these, they compress the seal, this should stop your leak.
USAF Retired
2006 F150
2008 Jayco Jay Feather G2 20BH
Wiscampsin
Wisconsin USA
Just a thought, that gasket/seal might need replacing after all those years.
2006 Toyota Tundra DoubleCab
2007 TrailCruiser C243S (traded in)
2008 Jayco Eagle 314BHDS
http://community.webshots.com/user/wiscampsin
dbbls
Missouri
Loosen the 4 bolts the previous poster mentioned, unplug the elec.. wires and lift the AC unit off. You will see a rubber seal that probably needs replacing. Clean the area under the seal real good, as well as the AC, and replace the seal with a new one.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
pointman77
Idaho
Tightened up the 4 bolts(they were fairly loose). Sprayed water and she's still leaking.Possibly a bad gasket?
pointman77
Idaho
Woops! Responded to second post without seeing the others. Thank you all for the advice.
pointman77
Idaho
Does anyone know the best way to locate one of these gaskets, searched google and really cant find anything but a universal one.
LAdams
Northern Illinois
A trip to your dealer or call to Camping World or Dyers or other online retailer would probably be a good bet...
Sometimes the roof will sag a bit after years of use... When you install the new gasket make sure the roof hasn't sagged and formed a low sop... The AC unit should sit on top of the crowned roof...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
