Treefrog
California-Oregon border
Some of the screws holding the lock cover to the inside of the fiberglass storage doors have worked loose and worked the holes wider.
After kicking themselves for failing to tighten the screws earlier, what do folks use to "narrow" the holes so the new screws get some bite?
I was thinking just a little dab of caulk.
2000 Country Coach Intrigue 36' 350 Cummins ISC
2002 Honda CRV
FMCA 351235
Look for us at Civil War Reenactments and the SCA.
thomasinnv
where ever i stop
caulk won't do it. if you can drill through and use nuts/bolts, that would be best. but if that is not an option, try filling the holes with fiberglass epoxy resin, and drill new holes.
2000 F-350 Extra Cab SD 4X4 7.3 PSD
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
LewMichele&Paws
Cowlitz County, WA
Use little plastic tips like they use to hold lag bolts in concrete. You can get them in all sizes at any home improvement store. Tap the plastic tip in then screw the doors back on.
Lew
Don't lose your head...to save a minute...you need your head...your brains are in it...Burma Shave
States visited in our RV...
Treefrog
Lew and Thomas,
both dandy ideas i hadn't thought of, yet have the stuff in the garage right now. thanx. i love the world of motorhoming; so many friendly folks.
thgoodman
Emery, SD
Harbor Freight sells a SCREW HOLE REPAIR KIT. Hundreds of teeth bite into the screw and wood for a perfect fit. I would guess that if it works in wood, it should work in fiberglass.
Tom & Jan
Fulltimers since April '06 with 3 fur kids (George - mini Aussie, Archie - mini Poodle, Kitty - 20 yo blind cat)
1991 Beaver Contessa towing 2006 Subaru (4 down)
Started workamping Sept '07 - This isn't too bad. Think we'll do it some more.
millertime
Whittier, Ca.
a couple wooden toothpicks dipped in wood glue will do the job nicely.
Chuck and Cindy
2002 Dodge 2500/Cummins
Reese 15000#
CF28BH Cruiser picked up 12-22-03
hyd/disk brakes installed 12/07
bldrbuck
Boulder, Colorado
I use JBWeld epoxy and re-drill
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
svlehman
Fontana, CA
Try This, Cheap and Easy fix
Rick Jay
Greater Springfield area, MA
I did the same as bldrbuck. I removed all of the screws and filled with JBWeld. Gave it a day to set up and redrilled. Then put the screws back in. They fit TIGHT and have not come loose yet.
I had to do the screws that hold the plate that connects to the pneumatic lift cylinder. The manufacturer of our motorhome thought that three screws on each plate would be sufficient. NOT! The plate was drilled for (at least) 7 (I forget the exact number). I drilled new holes for the rest of the holes and filled THOSE with the JBWeld as well, then redrilled them with a slightly smaller drill. Again, the screws went it with something to bite into. After 3 years, not a single loose screw.
Good Luck,
~Rick
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (12-Angel), 1 girl (7), 2 boys (8 & 5), 1 plump Golden Retriever.
2001 Honda Odyssey with Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
djevans
Tennessee
I use the toothpick idea. (toothpicks dipped in glue)
A little bigger? meat marinade skewers...
more strength? use bamboo meat skewers (glued)
more strength? drill the hole a bit larger and install "hardwood" dowels (again glued) - I keep a selection of dowels from 1/8" to 1/2" on the vehicle, although I haven't needed them yet on this RV, I used to use a lot of them on the old RV and my "brother-in-laws" RV (he travels with us frequently)
If you're still pulling them out after that, consider embedding metal plates (recessed surface or slot the material if you have the right equipment)
Caulk only "AFTER" you've correctly repaired the hole and re-drilled it (don't fracture the "repair material")
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
