kylamart
My three boys and I are vacationing in our 2008 Damon Astoria in San Antonio while my husband is at home working a few hours away. Last night I realized that the microwave was no longer working (the panel wasn't lit). After some investigation I found that a few of the outlets in the coach are not working - three or four in the "center" of the coach (near the microwave). Also, the front AC will not come on. Earlier today these things were working fine.
I have checked the breakers and none of them are tripped. I also went outside and reset the breaker at the electrical box to be sure.
I'm not very well versed in electrical systems, so I'm hoping this is something "easy"......I don't want to call a mechanic to come fix something I should be able to remedy myself. (and I don't particularly want to have to PAY a mechanic either)
Any help/tips would be appreciated so that I can get this fixed and use my oven and AC.
Thank you!
2008 Damon Astoria 3776
ronfisherman
SE Michigan
One leg of your 50 amp service may not be working. Try resetting the main 50 amp circuit breaker in MH's electrical box.
Saf-TTE tire monitor
Bumpyroad
Virginia
a GFI is tripped.
bumpy
Wherever I happen to park
In addition try resetting the MAIN breaker(s) in the rig
Just because a breaker LOOKS like it's on does not mean that it's not tripped I've seen many breakers were you could not visually tell they were tripped. You needed to reach out and touch it.. A gentle tap with a finger could tell, but not the eyes
tvman44
Southwest Louisiana
wa8yxm wrote: In addition try resetting the MAIN breaker(s) in the rig
I agree except just turn each breaker off then back on also check all your GFI breakers to make sure none of those have tripped. HTH
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
texasbaskets
Frisco, TX
ronfisherman wrote: One leg of your 50 amp service may not be working. Try resetting the main 50 amp circuit breaker in MH's electrical box.
The same thing happened to me because one leg of the 50A went out, but at the campground's service panel not mine. Most service panels have a 30A recepticle as well. Use your 50A-30A converter cord and see if that makes it work.
A good test is to unplug and run the generator. If the generator powers everything, that's another indication it could be the service line coming in from the CG.
Good luck...
Michael, Kay and Hans (our Mini-Schnauzer co-pilot)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
tvman44
Southwest Louisiana
tvman44 wrote: wa8yxm wrote: In addition try resetting the MAIN breaker(s) in the rig
I agree except just turn each breaker off then back on also check all your GFI breakers to make sure none of those have tripped. HTH  Excuse me I meant GFI Receptacles.
mockturtle
Northwest
Bumpyroad wrote: a GFI is tripped.
bumpy I agree. Try resetting it first.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
mike4947
N. Syracuse, NY
I'll have to go with a GFCI tripped. 50 amp services usually have two. One in the "bathroom area" and one in the "kitchen" area. If the bathroom one is not tripped you might find finding the kitchen one a problem.
For some reason several RV makers like to use the microwave outlet for the GFCI and in several cases we had to remove the microwave to find the second GFCI outlet and reset it.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
J.A.C.K.
Kelowna, BC
I'll have to go with a GFCI tripped also.
