Clint R.
Roseville, CA
Heading westbound 80 in Sacramento there was a motorhome with huge pictures of lemons and signs "worst RV builders" plastered all over it. These signs were on the fron side and back!
I did not get the make(I was heading the other way) but it looked like a newer MH with full body paint.
Wow...I guess things can get pretty bad to feel you have take matters this far.
bdpreece
Woodburn Oregon
And yet it was moving on down the road. Some people buy these things thinking that because they are spending a lot of money everything will be perfect. To make matters worse you meet others out there that have never had a problem (lucky them). Most of us though go through the initial shakedown with several problems and the associated trips back to the dealer for repair. In most cases the lemons are probably more a fault of the servicing dealer than the coach itself. Just met a guy who invoked the lemon law on a Winnebago when the dealer said he could not fix a slide problem. The problem was real but the lemon part comes in because of poor service tech's and a dealer that just didn't want to deal with the problem any longer.
Brian & Loretta
Chance (Golden Retriever)
2004 National Tropi-Cal T396
2005 Suzuki XL-7 toad
We moved!! No more nasty neighbors, no more rotten parking. I am saving this picture just to remind myself how bad it was.
50pascals
rochester, ny
I think "problem" in in the eye of the beholder.
In my expert witnessing I have been amazed at what some people called problems.
I am the type of person who just fixes everyhting I own myself. This way a problem that takes a few hours to fix doesn't turn into a multi-day, multi-hundred or thousand dollar event. Half the time its faster for me to fix something, than arrange dealer service, arrange a ride home, actually get it there, and then do it all over again just to pick it up 4 days later.
Economical Handyman
S. California
If it is the guy from S. CA., he has had something like 6 or 7 radiators replaced in that unit. Plus other issues.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
fourfurz
Memphis
There's no lemon law for RV's, anything could be his problem. My brother had a Ford Bronco that kept having the rear window pop out. This happened at least a dozen times, smashing in the road. Each time he brought it back the dealer would try again to fix it. After 3 years and a dozen windows, he finally filed for a lemon law claim and got the truck replaced. His next Bronco was perfect. What a pain in the butt!
Some vehicles are just junk, regardless of make, model or cost. Even the best manufactures can have a bad day.
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
rmmpe
Milford, PA
It's the Chaos Theory. Every so often a bunch of bad parts and appliances find themselves a home on the same unit.
Roads Scholar
Carry on, regardless
Alpine 36SDS
Cummins 330 ISC
Allison 3060
NoGoSlo
Walnut Creek, CA, USA
I think I saw the same guy on I-5 in March. It was a Country Coach and one sign said he'd had 7 radiators replaced.
B & B
Yellow Labs: Rusty & ZBar
Monaco Dynasty DP
bdpreece
Woodburn Oregon
NoGoSlo wrote: I think I saw the same guy on I-5 in March. It was a Country Coach and one sign said he'd had 7 radiators replaced.
Then the radiator is probably not the actual problem and someone should figure out what the real cause is. I doubt that every coach manufactured by that company has had bad radiators and after the second or third someone should be looking elsewhere. Here again a problem with poor service. On my own coach I have had 3 solar panels and controllers replaced. I am not stupid I know the problem; they mounted a wafer thin solar panel flat to the roof and when the coach flexes the solar panel gives up the ghost. My next solar panel will be raised on brackets and I will install it myself. Bet I don't have any more problems. Most coaches are not lemons it's just the service department that is a lemon.
maddog348
Bakersfield,CA
AMEN!!!!
Bruce Brown
Northern NY
50pascals wrote: I think "problem" in in the eye of the beholder.
I am the type of person who just fixes everything I own myself. This way a problem that takes a few hours to fix doesn't turn into a multi-day, multi-hundred or thousand dollar event. Half the time its faster for me to fix something, than arrange dealer service, arrange a ride home, actually get it there, and then do it all over again just to pick it up 4 days later.
Exactly. After Newmar went back to a 1 year warranty I was speaking with a larger dealer who said it was a double-edged sword. On one had the 3 year warranty was a good selling tool, on the other hand he was amazed at how many people wouldn't tighten a screw or change a light bulb for themselves.
I recent read (on another forum) of a person who had a list of 13 "major issues" and "needed to go back to the factory". In looking at the list I could only see 3 I'd even call an "issue", and I could take care of all 3 of those within a few hours in my garage. But...perception is reality to some people.
fourfurz wrote: There's no lemon law for RV's,
Not completely accurate, as it varies from state to state.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
