RV.Net Open Roads Forum: Class A Motorhomes: front tv removal????
 > front tv removal????
tonkatoys
maine
Posted: 07/23/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
we have a 27in tv mounted in the front console that we want to remove and put a flat screen in. my question is, i have a 24in wide entrance door, has anyone removed a tv this size and did it fit through the entrance to get it out? not sure what the depth is .
Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, loudly proclaiming---WOW WHAT A
RIDE!!!
Polishnurse
Schodack, NY
Posted: 07/23/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I was going to remove mine, but chickened out when I had drop it out of the cabinet. I believe it was not more the 19" deep. Which means you have to turn it sides ways to get it out the door. (thought you'd like that) Bill
C5man
Maggie Valley, NC
Posted: 07/23/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Got my 27" through a 26" doorway. Enlist two strong guys, and have another person on standby with wire cutters in case a cord or cable hangs you up. And yes, you may have to turn it a little, but it should go. And good riddance!
charwan
Dawsonville, Ga.
Posted: 07/23/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
It can be done. It will take two good men. That's the heavest thing I have ever seen for a TV.
N4FAP
ggeeza
Gilbertsville, Pa
Posted: 07/23/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Is it 27" wide, or does it have a 27" diagonal screen?
-=greg=-
'06 Diesel Bounder 39Z
You can trust your dog with your life... but not with your lunch.
OpenRoadsUSA
Lost In America!
Posted: 07/23/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
I recently removed a 27" Panasonic without any problem. Fit through the 24" doorway.
Also removed a sleeper sofa, after removing back and sides and it fit through the doorway also.
Good Luck.
Current Location: Ingram, Texas
2006 Allegro 34WA
2007 Nissan Sentra
2006 Master Tow Dolly HD80
1999 Aquasport 21 Explorer
tonkatoys
maine
Posted: 07/23/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
its a 27 in. diagonal panasonic. the front measures 26in. but i don't know what the depth is since it is still in.
tonkatoys
maine
Posted: 07/23/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck.
sounds like the same tv
Carvin Marvin
Livingston, Texas, USA
Posted: 07/24/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I removed the 27 Panasonic from my m/h it is mot 27 deep. You can do it.
OpenRoadsUSA
Lost In America!
Posted: 07/24/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
tonkatoys;
It was a gray panasonic, tapered in the back. I was surprised how easy it was to remove. My concern in removing it was whether I could handle it without any help. Went slow and all went well.
Did it myself, and I am vertically challenged.
If it is the same set, you will be surprised how easy it is to handle.
Good Luck.
