RV.Net Open Roads Forum: General RVing Issues: Surge Guard Adaptor...?
 > Surge Guard Adaptor...?
HUTCH45
NORCAL
Posted: 07/24/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Greetings.....
I've run into the same problem with a coupla' electrical pedestals where the surge guard "pigtail" is too short to plug the unit in safely, (the cord hits the pedestal rim/flange just below the plug and tilts the guard outward so that the plug wants to disengage).
I use the SurgeGuard Model#34730.
I was going to make up my own shorter 'Dogbone', but then I saw this thing:www.campingworld.com/shopping/item/rv-surge-protector-circuit-analyzer/35145.
Any thoughts from you folks...? Overkill? Bad idea? I'm not sure if it's what I'm after and even if it'll stay plugged in any better than what I have now because of the weight and the dual connections.
Thanks as always....enjoy the journey....
* This post was edited 07/24/08 11:49am by HUTCH45 *
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 34' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
d3500ram
9,500 feet in summit county, colorado
Posted: 07/24/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Over kill? Probably not.
I use THIS ONE. Seems eaier to use and plug in at the pedestal.
2005 Dodge 3500 SRW, Qcab, NV-5600, diesel, 4WD, Helwig rear sway bar, 9000XL
T.W.C. (temporarily without camper)
HUTCH45
NORCAL
Posted: 07/24/08 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your reply "ram". I edited my post to show what I use. It's just that some pedestals' plugs are closer to the bottom than others that's causing this 'problem'.
Texcam
Argyle,Tx
Posted: 07/24/08 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have the one from camping world you noted. When plugged into the pedestal it is a little to long and the bottom hits the lip of the pedestal and tilts the bottom outward also so the prongs aren't in all the way, but so far no problems.
Texcam
07' Coyote 23CFK
http://community.webshots.com/user/texcamp?vhost=community
rvten
Crossville,TN
Posted: 07/24/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
You can always make your own pig tail. Just buy a 30 AMP male/female plug and a nice piece of electric cable.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008
Class C passed Class A owner
(No Such Thing as a B+)Pontiac G6 2006
