RV.Net Open Roads Forum: Folding Trailers: Power converter doesn't supply 12 volts
 > Power converter doesn't supply 12 volts
eurobred
Burlington Ont.
Posted: 07/24/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Jayco Qwest 12A foldng trailer with a Centurion 3000 model CS1200 power converter . My problem is when conected to 110V power (from my house using extension cord) I get power to all 110V recepticals but no power for my 12V lights inside the trailer. When I attach a fully charged batery to the system then I get lights. The battery charge drops after a while then I lose lights even though I'm still contected to the house. I assume that the converter is not converting the power to 12V's nor charging my battery. All fuses are checked and okay. Nothing looks fried or out of place.
Any Ideas anyone? A dealer near me said it's fried without looking at it and wants $400 to replace it, (even if I do replace it he won't be getting my business).
Thanks to anyone who has the time to help.
Ron
mike4947
N. Syracuse, NY
Posted: 07/24/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I wish I had a dollar for every Centurion converter problem I've worked on over the years.
Not the best converter.
If it were me I'd drop the folks at Best Converter an email or a call. They are experts and won't steer you wrong. Not to mention they'll charge you a heck of a lot less for a better converter that will be an easy DIY replacement that fits the current location if it does need replacing.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
JFG
TN
Posted: 07/24/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Two steps to see if converter is good or bad. see below link.
converter
Fred
pete42
Jamestown, Ohio
Posted: 07/24/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
EDIT
They have better answers than mine.
mike4947
N. Syracuse, NY
Posted: 07/24/08 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Even if JFG's link test fails it doesn't mean the converter is "bad". Centurions have a small 7.5 amp Buss fuse actually on the circuit board that's designed to protect th converter board from reverse polarity (hooking the battery up backwards). One touch backwards and the fuse blows. Problem is it also has a habit of blowing for no apparent reason. I used to carry a box of them for folks...LOL
It's on the board itself so you have to open up the case to find it.
Also the Centurions have minimal battery charging ability. They rely on just the normal use voltage, rather than having a dedicated battery charging stage, which isn't enough to fully charge the battery.
OnaQuest
Raleigh, NC
Posted: 07/24/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice given above. A quick (temporary) fix would be to use your battery charger as a converter. Simply attach it to your battery and plug it into the 110v service along with your regular trailer cord.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
eurobred
Burlington Ont.
Posted: 07/24/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Great help from everyone, when the thunderstorms stop here in Ontario I'll go out and do the check. I have checked the reverse polarity fuse (6amp in my case) and it looks fine. The real issue I have is that the converter isn't converting 120v to 12v. I think I'll forgo the whole converter issue and just bring my battery charger like OnaQuest suggested.
Thamks for everyones time.
Ron
