RV.Net Open Roads Forum: Fifth-Wheels: Superglide bangs unhitched
 > Superglide bangs unhitched
pinemountainjohn
Pine Mountain Club, CA
Posted: 07/24/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
When we stop and start while driving the tv unhitched, the hitch slides and bangs. What am I doing wrong? Thanks.
John and Nina
2005 F-350, 4x4, V-10, Crew Cab
2008 Cougar 276 RL
Butch50
Roseburg (not for much longer), OR
Posted: 07/24/08 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Get your manual out on it and adjust the front block. If you look right in the very front of the hitch you will see a white block of nylon. There is a bolt on the front of the metal plate attached to it with a nut to lock it in. Adjust the nylon block to help hold the hitch in the forward most position. you don't want to tighten it down to much as then it wears out the block. Just enough to hold it in place.
Look at page 10 of the manual
This is IMO
Butch
2006 F550 CC 4X4 Lariat PSD/Torqshift Dark Shadow Grey Metalic w/Manning F350 bed
2009 Excel Limited 30TKE (Now have it)
2006 Dodge 3500 Laramie 4X4 QC SB SRW/Cummins 6 speed Jake exhaust brake
pinemountainjohn
Posted: 07/24/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, that's it. Read the entire manual when I got it, then forgot everything. When in doubt read the manual! Problem solved.
radio flyer
staten island ny
Posted: 07/24/08 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
When you make the adjustment, and have no more play, turn 1/2 turn then lock
the nut. I had the same problem with mine. I hope this helps you.
califasramsfan
Central California
Posted: 07/24/08 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
I don't need no stinkin manuals...just another man's opinion!
califasramsfan
Central Calif.
05 Chevy 4X4 2500HD Duramax Crew
06 Cardinal 37RL, 5500 LP Onan Gen.
"Hotel California" Cardinal 37RL
flhtse05
Pace, Florida
Posted: 07/25/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
They came with a manual! I thought that was just packing material.
vonzoog
Delaware
Posted: 07/25/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Don't feel so bad. It seems that just about every other trip out I run across another SuperGlide owner who is complaining about the same thing. "My side is banging around when not hooked up". Then I walk over in point out the adjustment bolt on the front of the slide and the same amazed look comes over their faces.
It's a guy thing. Never read instructions until you grow older and wiser.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
jlvtx1800
Buffalo
Posted: 07/25/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Before I adjusted mine I used a bung cord to keep is from sliding back (didn't have time to adjust at the time). It is a good band aid.
- 2008 Ram Laramie MC 4x4 SRW 3500 CTD 6.7L 6 speed manual
- 2008 Jayco Eagle 345 BHS
Arcamper
Fayetteville, AR
Posted: 07/25/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
This is new to me because mine has never moved at all when unhitched. Learn something new every day I guess.
2007 Keystone Laredo 29RL 5th
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
Pullrite 16k Superglide with Super Rail kit
Brakesmart
Delaine and Lindy
Linden Tn. (The View)
Posted: 07/25/08 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Well thats one of the many great things about the B&W system. It has a small shock absorber that want let the hitch rattle or move around. I had 3 other type 5th wheel Hitches and they all made noise. GBY....
2008 Chevy Silverado LTZ 3500, DRW
2008 Chevy Equinox LTZ
2009 Mobile Suites 36TK 3
B&W Hitch
www.webspawner.com/users/lnhdch
We are Blessed !!!!!!
