RV.Net Open Roads Forum: Class A Motorhomes: 50 amp service question
 > 50 amp service question
bullydogs1
New Jersey
Posted: 07/24/08 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
My brother in law is having a 50 amp plug put into his garage for us to plug into when we stay at their shore house....It should be a 50 amp breaker with one hot from each "phase" plus the neutral and ground....the plug is being placed right next to the 200 amp panel in his garage...my hookup was done by a friend of my brother's when I wasn't home and it works just fine.---(wish I was home when he put it in--but there is a 50 amp breaker --dual phase---in the electrical box now at my home... am I missing anything to tell my brother in law? (boy what a a loaded question).....
Thanks...
Stuart and Stella Denning
2006 Coachmen Aurora (workhorse chassis with Konis)
the 4 Bulldogs (Summer, Sully, Sierra and Great-Grandma Demi)
2007 Saturn VUE AWD (Our Toad)
One worn out Debit Card
Buck62
Charleston, South Carolina
Posted: 07/24/08 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you got it right. Each hot leg is 120 volts plus the ground and neutral. This web site has some great wiring diagrams that will help guide you.
http://www.dasplace.net/RVWiring/wiring.html
colochoclab
Arvada, Colorado
Posted: 07/24/08 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Buck62! Iwas loking for the same thing but in 30A!
-Lab
2004 Nissan Titan SE Crew Off-Road & Big Tow, LT Tires
2006 Jayco JayFlight 29FBS
Equal-i-zer Hitch
Prodigy Brake Control
Member of clubtitan.org
"Hershey" the Chocolate Lab (Best Friend)
"I asked God for a true friend: He sent me a Labrador Retriever."
fourfurz
Memphis
Posted: 07/24/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
What you want to install is no different than a 50 amp service for a stove or dryer. The plug you want is a bit different, it's technically called a NEMA 14-50
Straight Blade Receptacle, Current Rating 50 Amps, Voltage Rating 125/250 Volts, Number of Poles 3, Number of Wires 4
2007 Mountain Aire 4528
2006 CRV SE
Based in Memphis area
smkettner
Posted: 07/24/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
It is all in here: http://www.myrv.us/electric/
JerryofWV
Charleston, WV
Posted: 07/24/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Lab
Don't confuse the 50 amp and 30 amp hookup. In the 50 amp you have two 120 volt wires and ground. In the 30 amp you only have one 120 volt wire.
A friend of mine insisted that the electrician wire his 30 amp with 240 volts and burned up several appliances in his trailer.
Jerry & Dee Dee Pauley
1998 Pace Arrow 36S, One Slideout, Tag Axle, Triton V10, Front Konis, Rear Track Bar, 2000 Tracker Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
DeweyClawson
Enon Valley, PA
Posted: 07/25/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I got a 70 amp outlet from Lowes. It has the correct 50 amp, 240v plug plus two 20 amp 120v GFCI outlets in an outdoor box. 50 amps for when you are there and 20 amp plug for him when he needs to plug in the electric hedge trimmer.
