RV.Net Open Roads Forum: Fifth-Wheels: Anybody replaced Dexter pin box on Jayco 5er?
 > Anybody replaced Dexter pin box on Jayco 5er?
whs9841
San Antonio, Tx
Posted: 07/24/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at replacing the existing Dexter pin box on my 2008 Jayco Eagle 5er with the Trailair Air Pin or the 5th Airborne. However, the Dexter pin box isn't listed in the "replacement" pin box for either product. It has the typical list of Lipperts, etc. Do you know if the Dexter pin box is identical in hole placement and measurements to any other more popular pin boxes?
Thanks in advance.
2007 Chevy 2500HD Z-71 D/A
2008 Jayco Eagle 341RLQS
Dual Honda EU2000's with parallel kit
DW, 10-wk old daughter, 1 yr old yellow lab
Hannibal
Gas Station
Posted: 07/24/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Dexter? Could it be "Leland Engineering"? The chassis is made by Leland Engineering. I don't know if the two are related or not. I'd check with Jayco about warranty with any extended pin box that isn't factory just to be safe.
'05 2500HD Dodge 5.7L Hemi 5spd auto/3.73 SLT. 90k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins
'07 KZ Jag 28JFSS.
RollingRockTX
Keller, Texas
Posted: 07/24/08 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, you probably have a LeLand 7920 (Just a dexter sticker on it), replaced mine with a 5AB
Wanna buy it from me?
I would like to sell it but if you have a SB, get the 5th AB with Sidewinder...do it right the first time.
Cheers
RR
2006 Ford F250 King Ranch PSD
2008 Jayco Eagle Super Light 31.5BHDS, KC5PFG,
5th Airborne, Plug-It-Right Stabilizers Wooden Camper Sign
benb21601
Resident Expert
Posted: 07/24/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Great decision-highly recommended. As previously said, your frame is made by leland engineering. Dexter provides the axles and running gear. You will need to get either an L08 or M17 from trailair. The only difference between the two is that the L08 is 5 inches longer and is classified as an "extended" pinbox. I see you have an 07 hd. If it is the new body style, MAKE ABSOLUTELY SURE YOU GET THE M17!!! The new body style trucks have a deeper bed and wider bed rails and the extended version will have contact with the rails. It will clear on level ground, but any off angle maneuvering, and your day will be as bad as mine was. If you have the old body style, it doesnt matter. The extended is nice for additional cab clearance and maneuvering, just not on a new body style truck. IMHO, the trailair is the way to go. It has the most movement to provide for maximum travel and suspension. Infact I have an extended Im trying to swap for a shorty. As far as the frame warranty goes, my dealer installed it and verified with Jayco that there would be no issues in the unlikely event something happened. Surprisingly, they were happy about it as the suspension it provides eases some of the stress on frame. Good luck-hope this helped.
07.5 GMC Sierra 2500HD SLT-Crew Cab Short Box, LMM, SuperGlide, Prodigy
07.5 Jayco Eagle 345BHS-Trip Slide 5er, TrailAir Pinbox, Shocks, Aluminum Tripod, RotoChocks
04 Honda EM5000S Generator
Me,DW,DS,DD,DGSD
Our Picture Page
whs9841
San Antonio, Tx
Posted: 07/25/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
My pin box may be a Leland, but here is a link to my pinbox and it is labeled as a Dexter: http://l.b5z.net/i/u/6069975/f/Service%20Bulletins/Service_Bulletin_7926_rev_1.pdf
Has anyone seen this pin box on their trailer or anyone else's?
It is considered a long pin box. I moved it down to the lowest setting to get maximum clearance at my rails (currently about 8 inches). I also raised my trailer 1 inch to get a level ride.
I'd like to stay with a long pin box as long as I can still get 7-8 inches of clearance at my rails. Is this not possible with the L08?
I would think your manufacturer would encourage all of their customers to attach some type of pin box suspension to alleviate some of the strain on the trailer frame. I'd be surprised if that voided the factory warranty.
Hannibal
Gas Station
Posted: 07/25/08 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
That's interesting. Dexter and Leland Engineering must be related or have merged or somehow become one. That is definitely a picture of what used to be or is still made by Leland Engineering. Two good companies working together have become one?
http://l.b5z.net/i/u/6069975/f/Service%2........ulletins/Service_Bulletin_7926_rev_1.pdf
RollingRockTX
Keller, Texas
Posted: 07/25/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Same pin box that I have....5thAB will NOT void your Jayco Warranty or your Dexter Warranty. I spoke with Sonny at length about this. 5th AB and Jayco do have an agreement together and you can order a Jayco with a 5thAB already installed from the factory.
If you want to talk to him and get all the details...PM me and I will get give you his phone number.
Mine is listed on Craigslist right now!!
Cheers
RR
RollingRockTX
Keller, Texas
Posted: 07/25/08 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Cheers
RR
BTW, Leland makes the Pin Boxes for Dexter.
jaycocamprs
Ringgold Georgia
Posted: 07/25/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Dexter Axle bought Leland Engineering in 2005. When we bought our 07 Jayco the 08's on the lot had Dexter labels on the frame components and pinbox. Seems the name changed with the 08 models.
2004 Silverado 2500HD
2007 JayFlight 28.5 RLS
