RV.Net Open Roads Forum: Class A Motorhomes: Blow out, Goodyear G670RV
 > Blow out, Goodyear G670RV
helperzack
Port St. Lucie, FL
Posted: 07/24/08 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Tuesday night on the last leg of our trip, an hour and a half from home. I was rolling along at about 63-64mph, BANG, I look to my left and see a bit of smoke. I slow down and safely off to the edge.
As I get out to inspect to see what happened, it was my front driver side tire. A blow out. The MH handled great getting off to the side as I had no idea it was the tire.
Got a replacement tire and the guy told me to go to goodyear and ask for a replacement. I only had 8100 miles on them.
Has anyone else had any success in getting Goodyear to replace a tire with sidewall failure?
I figure it is worth a try. It is the original tires which came on it.
’07 Coachmen Mirada 310DS
Counting my blessings with my high school sweetheart.
3 kids, 39 foster kids(not all at once) 2 boys currently
Do you have room for a child? Consider fostering/adopting a child. Thousands of children are in need of a loving family.
brobox
Sunny SW. Florida
Posted: 07/24/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I have. It was on a one year old Chrysler that was under warranty. one of the front side walls developed a bubble on it, took it into Goodyear and left with both front tire replaced, no questions asked.
Chuck
02 Travel Supreme, 2 street side slides
02 Jeep Liberty Toad
Tenn Stud
Northeast, TN
Posted: 07/24/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I blew a right front at about 70-75. 4100 miles. Total refusal by Goodyear. I put Michelin XZA2 on the steer axle 9090#'s each
cptdav
North Mississippi
Posted: 07/24/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't had a blow out but did have two tread separations. One last year and one this past may. Both times caused damage to fender skirts and sheet metal. Both times goodyear sent the tire to Akron for inspection. Both times goodyear paid for the damage and a new tire. This was a G rated tire with 12 plies. For some reason we are hearing more and more tire problems. I know I was not over weight and was aired to proper psi.
JD
2007 Phaeton 36QSH, Titanium Pearl, 330 MBE926
2001 Jeep Grand Cherokee Laredo, Royal Blue, 4X4
Fred B.
hinckley, Ohio, USA
Posted: 07/24/08 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Had one three years old blowout, dealer sent it to Akron, Akron sent me a check.
Fred B.
Hinckley, Ohio
00' 35U adventurer, SMI Stay-n-play aux brakes
99' dodge caravan toad
Deen
Vancouver, WA
Posted: 07/24/08 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Remember all the "bad press" about Michelin failures? Now it's catching up to GoodYear too!!
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Don Don
Pleasant Grove, AL
Posted: 07/25/08 02:32am Link  |  Quote  |  Print  |  Notify Moderator
How do you know if you did not have a slow leak and then it blew? Do you have a pressure monitoring system?
alcolby
yuma az.
Posted: 07/25/08 03:00am Link  |  Quote  |  Print  |  Notify Moderator
If your "tire guy" was not a GY dealer, there is your problem... the logistics to get it inspected by GY.
If it was not caused by low inflation pressures, they can tell, then I would think GY would make good on it.
Al C
jerseyjim
New Jersey
Posted: 07/25/08 03:56am Link  |  Quote  |  Print  |  Notify Moderator
My blowout was the inside rear tire, drivers' side. Hit something....hole about the size of a quarter in the inside sidewall. Happened at 27,000 miles, tho...so I was on my own. End result...bought NEW Goodyears (and 4 shocks). Now...8,000 miles on the new ones and all's well. So far.
Good luck!
DeweyClawson
Enon Valley, PA
Posted: 07/25/08 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Zack; Do you have a TPMS?
if so, did it give any warning at all?
