RV.Net Open Roads Forum: Travel Trailers: Plug in on vehicle
 > Plug in on vehicle
Crane Man
TN
Posted: 07/25/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Does the tow vehicle keep the battery charged on the TT?
plex
MD
Posted: 07/25/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
You hope it does.
Polishnurse
Schodack, NY
It does, but only if your tow Vehicale is set up for it. You will most likely see what is called an isolation device mounted on the engine wall, wired in battery cables, and connected to alternator. JM2Cents Bill
thomasinnv
where ever i stop
Posted: 07/25/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
some vehicles do not have a battery isolator, but will be wired so that there is only power to the tt when the ignition is on.
2000 F-350 Extra Cab SD 4X4 7.3 PSD
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
Rvndave
Medina, Ohio
Posted: 07/25/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
If wired properly the TV should charge the TT battery when the Tv is running.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
jimdubya
Paducah, KY
Posted: 07/25/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
To see if your TV is sending 12 V to the TT battery, open the connector cover on the TT. Using a multi meter or a test light, you should detect power between the first pin past ( right of)the 12 o'clock position and ground. The ground pin is the first one past (left of)the 6 o'clock position. If you detect power there, you are sending volts to the trailer when hooked up.
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
Tvov
CT
Posted: 07/25/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Double check that ALL of your tow vehicle's fuses are in place. Many times tow vehicles will have separate fuses for trailers, and those trailer fuses may not come installed from the factory.
2008 F-250 CrewCab 5.4L,
robbie69
wauconda, il usa
Posted: 07/26/08 06:08am Link  |  Quote  |  Print  |  Notify Moderator
chevys are good for this. i found out about this practice when i dropped the TT off at the dealer and the ele jack wouldn't work-even while hooked to the TV. found and fixed this befor picking up the TT and jack worked fine. on mine w/tow pkg they put in a 'dummy' 40 amp fuse-just replace with a real one and works fine. on the flip side, if you leave the TV/TT hooked together for any length of time you run the possibility of draining both battries. even though my last 2 TV said they had a circuit built in to keep the TV batt from draining below a certain level-take it from me-i don't work. found this out a few weeks ago with present TV while on vacation. left back up cam monitor on for several days and when i went to move it-nadda. luckily i had packed the charger for some reason and it did come in handy.
2004 silverado 2500HD crew cab 4x4 long bed 8.1L gas hog
2006 skyline nomad 3260 platium edition, prodigy, reese dual cam
1 very part time camping son and 3 full time camping, 4 legged fur balls
1 SU (spousal unit) who loves rv'in as much or more than me
strollin
San Martin, CA
Posted: 07/26/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Even if the TV supplies 12V to the trailer, in most cases the wire gauge is too small to provide any decent charging current so unless you drive quite a few hours the TV won't do an adequate job of keeping the trailer's battery charged.
Me, her, 2 boys & 2 girls
'05 Chevy 2500HD LT 4x4, D/A
Reese Dual Cam HP
'04 Wilderness Advantage 290FLS
Twin Honda 2000s
"I'd rather wear out than rust out!"
"Two hands at work accomplish more than thousands clasped in prayer"
See our pics here
Tvov
CT
Posted: 07/26/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes, don't depend on the TV "recharging" the trailer's battery. Consider it more of an "maintenance" charge.
