RV.Net Open Roads Forum: Class A Motorhomes: Tire Prices
 > Tire Prices
Tarheel 2
North Carolina
Posted: 07/26/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Had to buy two new front tires this week due to an alignment problem. I have the Goodyear 670's in a 275-70R22.5 and wanted to buy the same tire for replacements. I've had great success with that tire on my last two motorhomes. I had purchased a new set of the same tire for my old rig three years ago and I paid $310/tire. The ones I purchased this week were $530/tire mounted. That's a 71% increase in three years.
$530 was the lowest quote I received. Other quotes ran as high as $590 in the Raleigh, NC area. Just though I would pass this on along for those that are facing a tire replacement in the near future.
Another example of what oil prices are causing.
Tarheel
LandYachtLadySandra
Angleton, TX
Posted: 07/26/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
In early June, we bought six new Michelin 275/80 22.5 ZXA3's.
$500 each mounted and balanced at Zolman Tire near Elkhart, IN.
Joe
LandYachtLadySandra
2004 Fleetwood Revolution 40C
2006 Dodge Dakota Club Cab 4X4 carrying two EGO electric scooters
KE5LUU
Chipper, the 7 year old 7 lb chihuahua/? mix, a rescue dog
Sassy, the 1 year old 4 lb. chihuahua/pomeranian, his "sister"
joebullits
Cleveland, Ohio
Posted: 07/26/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Know what you mean. I just priced 245/70 X 19.5 at $395.00 per tire mounted and balanced, and I know the owner...go figure
mpmeisch
Aurora, IL
Posted: 07/26/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Costco has several Michelin tires for RVs at pretty good prices. No good year though.
Flying for work, cruisin' for fun!
2001 Itasca Suncruiser
MI Director
Michigan
Posted: 07/26/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have an appointment for 2 new front tires on Tuesday Cooper 8R19.5 for $250 balanced, new stems and installed. I'm replaceing the front 2 Coopers that are worn after 8 years about 38,000 miles. Tires have no cracks or side wall damage just tread wear. Some tires are just build better than others. That's only about $45 more than I paid when I put them on 8 years ago.
Conkl
Wirtz, Virginia
Posted: 07/26/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just put on 6 Bridgestones 8r 19.5 (load range F) a couple of weeks ago $1560. out the door with spin balance and stems. $260 each.
Kevin & Lorry
1987 Holiday Rambler Preidential (28)
1995 Geo Tracker
Falcon 5250
Brakemaster 9000
cdzranch
Snowflake Az
Posted: 07/26/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
245 70Rx19.5 Toyos M143 Load range H $270 mounted and balanced 2 wks. ago, but he said the price was going up to $300 each
Dan and Cindy FMCA# 402249
2002 Itaska Suncruiser 37ft (1) slide W22 Workhorse chassis; 1990 Komfort Trendsetter 25ft 454 4bbl carb
Tow VW manx bug; '07 Honda Shadow 750
Snowflake Az.
"If you don't learn something new every day, you've wasted that day!"
The Texan
Summer: A Cool Climate Winter: A Warm Climate
Posted: 07/26/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
You are paying 40% for the name and 60% for the tire. I use Toyo tires just for that reason, price is for the tire, not for the name. Michelin RV tires are junk and now Goodyear RV tires are approaching the same status with their rivering problems, but GY is denying they have a problem. Tell that to the hundreds of RVers that are throwing away low mileage tires that have started rivering and once started, can not be stopped.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03
FMCA #F203528
'05 HR Endeavor, 40PRQ w/400 Cummins - With -'05 GMC Sierra SLT, CC Z-71, the pusher
'07 Arctic Cat 500A & Wilderness Kayak, riding in the pusher -
Our Current Location
trailmeisterjoe
bothell, wa
Posted: 07/26/08 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
what is "rivering"?
'99 rexhall rexair with 2 slides 32 ft
The Texan
Posted: 07/26/08 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
trailmeisterjoe wrote:
what is "rivering"?
It is an abnormal wear pattern(wave pattern) on the front tires and once it starts, Goodyears says to move the defective tire to the rear, however, not one person has reported that the wear stopped with the move. Every report I have seen on this and other RV sites, have said that once the wear starts, it will continue and even accelerate, no matter what position the tire is mounted. This has just recently(past 18-24 months) been reported and usually starts with 3 to 11K miles on the tire and the tire is shot in as few as 3K more miles. Goodyear is blaming the RVers and refusing to accept responsibility, as Michelin did with their side wall zipper blowouts.
 > Tire Prices
