stevelv
FullTimers at Last!
Not sure whether to put this in Tech or Class A but as it's about Class A windows I'll try here.
I'm heading for a month in Las Vegas and Lake Havasu on business and it's going to be 105+ - even though I have dual air etc it's going to be hot.
Anyway, I found a 'static cling' film that's intended for the OUTSIDE of the windows (the best way of applying heat reducing film) BUT it says to apply in no more than 90 degrees. I'm in the Bay Area at the moment with temps around 70 and so my question is, has anyone installed this type of film on the OUTSIDE of their windows and then driven the Motorhome? It seems to adhere very well but I wonder if a strong breeze will remove it down the freeway?
RV Park Finder
Fulltimers
2002 Beaver Santiam 38DST + Banks + 99 Jeep GC
DH,DW,Jake and Indie
Polishnurse
Schodack, NY
I've always seen it on the inside, never on the outside. JM2Cents Bill
ON EDIT; I was just informed by a member that adding reflective film to the inside may cause failure on double pain windows. I will have to agree with that assessment. I seems logical and well within reason. I will have to and sulk for two hours..
edited 08/04/08 08:09pm by Polishnurse *
mblaster
Los Angeles
We spend a lot of time boating in havasu on 110+ days Though we don't have screens on the windows our 30 amp RV stays cool with the slide out. We put 2 reflectors on the windshield and close the drape to block the morning sun. Other than that just set your ac, open the awning, and you will be fine.
01 Southwind 32V
02 Grand Cherokee toad
21ft Carrera Elite daycruiser (summer)
stevelv
FullTimers at Last!
If you have dual pane windows you should not put heat refelcting film on the inside - I know thousands do use that foil and don't seem to have problems but I am reading the instruction leaflet that came with the film - it's called Glare Control film from Gila - it specifically says that it's to be applied to the outside of the glass and that heat reflecting film should never be applied to the inside of dual pane windows as it can cause damage.
Obviously putting it on the outside stops the heat/light from entering the coach to be reflected back through the glass.
mblaster - unfortunately we have 3 big slides and an extra 6' and a DW with hot flashes - doing nothing was not an option LOL
mockturtle
Northwest
The best way to keep heat out is window awnings. Pricey, perhaps, but very effective and they look good, too.
2000 Born Free 24RB Class C
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
flaja
anywhere,usa
Don't forget your vents & skylight in the bathroom (if you have one). You'll be amazed how much heat comes in from these.
- Roy & Jacqui
- Retired firefighter & X-ray Tech
- 2003 Fleetwood Revolution
- Fulltimers since 2004
YC 1
Yuba City Calif.
So please share that source. I am considering the same thing with some heavy static cling stuff designed for the inside. I am going to try it on the outside when parked but would love it if it hangs on during transit. Nothing on the inside helps very much. Even the bubble reflective stuff is only marginal. Awnings would be fine but I really would like to stop the darn heat before it even attempts to enter.
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
tupelo
tupelo, ms
We use Reflectix on our bedroom windows. It not only helps "insulate", but it also keeps the bedroom dark so the "better half" can sleep in without the morning light bothering her! This has been on the bedroom windows for over 3 years now with no problems with the windows as of yet!
http://www.lowes.com/lowes/lkn?action=pr........l&productId=13357-56291-13357&lpage=none
1995 Fleetwood Bounder 35UW
USE & SUPPORT CB CHANNEL 13
mblaster
Los Angeles
stevelv wrote: mblaster - unfortunately we have 3 big slides and an extra 6' and a DW with hot flashes - doing nothing was not an option LOL
A lot of the guys with big pushers with many slides at the lake have 3 roof airs.
My cousin bought a new quad slide monaco in 05 and he's kicking himself for not getting the 3rd roof air. It wasn't much money at the time. He has a hard time keeping his rig cool at the river. Granted he has kids going in and out all the time. So keep her closed up as much as possible and crank that ac.
I know if I ever order a new dp I'll be checking that 3rd ac option box.
stevelv
FullTimers at Last!
YC 1 wrote: So please share that source. I am considering the same thing with some heavy static cling stuff designed for the inside. I am going to try it on the outside when parked but would love it if it hangs on during transit. Nothing on the inside helps very much. Even the bubble reflective stuff is only marginal. Awnings would be fine but I really would like to stop the darn heat before it even attempts to enter.
Here's the link it says glare control but in the store it says it's also for heat reflection.
I bought 3 rolls of the stuff from Home Depot - about $12 a roll and that's enough for all of our windows. You cut it to size and then clean the windows and spray with a lubricant spray and squeegee it on. Makes the windows darker and they look reflective black from outside.
It's not a perfect film like when they darken your car windows professionally, some visual distortion but then they are temporary.
If you wait a week I'll let you know if they survive 300 freeway miles LOL - I think they will be ok unless an edge lifts.
When you buy it, make sure you get the Static Cling rather than the permanent adhesive
edited 08/04/08 09:40pm by stevelv *
