jchonroad
South Berwick, ME
We have a VENTED Splendide, and it does a great job. You just can't overload it for drying.
John
John '46
Joyce '46 (DW)
GOOD SAM LIFE MEMBERS
Heidie '00 (13 lb."Guard Dog")
'05 Winnebago Voyage 35A
'03 Cavalier Toad w/Sterling Aluminum Tow Bar & Brake Buddy
Also: '96 Coleman Yukon behind a '03 GMC Sonoma with a Prodigy Controller
dav5942
Stuart, FL
If you have ever used a ventless LG you will never go back to a Splendide vented or ventless! No wrinkles, larger load same dimensions! But obviously a stack or side by side will do more faster and better, taking up more space of couse.
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,lifted Jeep(s) in tow, Hog Valley Florida(a diamond in the rough),'09 Alaska again!
2007 Tour Alaska Fishing '08 Tour Grandchildren Newmar Mid Engine
BigSkyBob
Western Montana
We had the coach plumbed and wired for a washer/dryer when it was ordered. We had the Splendide Ariston stacked units installed by CW and they did a great job. It is a vented dryer and the washer does a good sized load with ease. The dryer runs on 115 VAC but will dry a full load in 55 minutes every time. They both run off of one 20 amp breaker and we run both at the same time and have never tripped a breaker after about 40 loads. I've never felt the coach shake when the washer spins.
2008 Monaco Camelot 40PDQ, 4 slides, 2008 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Once you're dead you have lost a very important part of your life.
Larry Cohen
Mobile, AL
We like our Splendid 2100...it wont do a big load but is very efficient..using almost no water or power..about 2 1/4 hours for a load to wash/dry...
2006 Mountain Aire 43
Wife, K9 Maggie and 4 sugar gliders are co-pilots, along with Garmin Nuvi 660
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Want it done right, use the campgrounds laundry.
Todger
Newville, Pa., USA
We love our vented combo. The trick seems to be pull the clothes out after washing, shake and then put back in to dry. Works great.
Mr.Mark
California/Tennessee
We have the Splendide stacked washer and dryer (vented). Wow, we wouldn't want to be without them. We don't like using the campground laundry facility as you don't know if bleach or dye is left in the washer. We had a few things ruined when using a campground washer so we would rather stay away from them.
Our washer is a front loader and is very water efficient. The dryer drum will turn one way for a minute then switch back and roll the other way. That keeps the clothes from bunching up and does a better and quicker job of drying.
We feel that we don't lose any space with the W & D as we find the units very valuable.
MM.
Mr.Mark
2008 Monaco Dynasty, 42ft., 4 slides, 425 hp clean-air Cummins diesel
2007 Honda CR-V EXL, AWD, w/Nav and the M&G braking system
triboy
Vancouver, B.C.
We also have the Splendide Ariston vented dryer and front load washer, my wife thinks they're fabulous.
SteveRankin
Sequim, WA
We had a vented Splendide and were very happy with it. We also heard about problems with the unvented versions, but don't have any actual experience.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
UltimaRV
USA & Europe
There is a reason they only put stacked washer and dryer units in a Featherlite Prevost (yes those people do washing). The're by far better. They do take a bit more space upward where normally you would store towels etc, but once stacked, you'll never go back
Of course on our lower-end cousin, we have the vented Splendid and it works fine.
Dian, Robert & Precious - Presently RV'ing in Europe!
2000 45' Featherlite Vogue 5000, tag, slide, Detroit Series 60
2006 19' Towcorp enclosed trailer w/60" tongue
2004 13' Ultima GTR (9.9 seconds standing quarter mile)
