RV.Net Open Roads Forum: What is the best aftermarket water pump out there??
RV.net
 > What is the best aftermarket water pump out there??
T_S_L
Lansing Illinois
Posted: 08/13/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Im looking to purchase a new water pump for my Jayco TT. I have the stock water pump now and it is way to loud for me... I was looking to get info and prices on what the good and quiet pumps are out there on the market. I looked through the forums but couldnt find anything. Thanks in advance!
DrScud
On the Road
Posted: 08/13/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Lots of people like the Shurflo 5.7 Extreme.
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
ScottG
Bothell Wa.
I bought the Sensor 5.7 and I'm very happy with it. It's quiet because it runs at varying speeds depending on demand. If your just washing dishes or your hands it run super slow. Multiple things running at the same time causes it to run harder but it's still more quiet than normal pumps.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
Honda eu2000i
The Texan
Summer: A Cool Climate Winter: A Warm Climate
Posted: 08/13/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
We use the Shurflo 4.0 Extreme and have found it to be excellent. The 5.7 is an overkill, IMHO, as your RV supply lines can not supply that volume to the fixtures. Also the Shurflo 3 year warranty is solid. Ours broke(my fault) after 2 1/2 years and they exchanged it on the spot, no questions asked.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 & FT Class of 2003
'05 HR Endeavor 40PRQ, 400 Cummins -With-'05 GMC Sierra SLT, CC, Z-71, the pusher & our '07 Arctic Cat 500A & '08 Suzuki KQ 400A, riding in the pusher.
Where the wheels are stopped
tatest
Oklahoma
Posted: 08/13/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
If your water pump noise is coming from water lines drumming against walls and cabinets, replacing the pump is not always a complete fix. Try to isolate and quiet line vibrations, before jumping into a pump replacement.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
SJR
Philadelphia, PA
Posted: 08/13/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
What he said
Stephan
2003 Jayco Kiwi 21C
2008 Dodge SLT QC 1500
Equalizer
Jordan Brake Controller
TMBLSN
Washington State
Posted: 08/13/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed. The noise is probably from the pump shaking the pipes.
That said, there is no good 'aftermarket' pump. Shurflo is by far the leader in the industry in these come stock in most (all?) RVs. They have different models, though, and the 'stock' version is usually not their best.
2006 Jayco 275BHS
1998 C2500
Lee
PUCampin
Castaic, California, USA
Posted: 08/13/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
I'll third the suggestion to check waterlines. I thought ours was sooo loooud!!! I was considering a replacement. Then I ran out of water at a campground that was not supposed to be a dry camp, but was. The pump kept running, but was almost silent!. I discovered that the water lines are not really held down in many places, so I either attached the line, or wrapped it with some cut up scraps of cloth and zip tied it, voila!! My pump is inside the undersink cabinet, and it is easy for a loos bottle or what not to roll up against it and then it makes a racket too.
2007 Expedition EL 4x4 Tow pkg
2006 Pioneer 180CK (No more pucampin!)
Nights in 08: 6
Nights in 09: 5 (Gotta change that!!)
Me DW and the 3 under 3
DD 6/14/06, DS 11/27/07, DD 11/11/08
Bubby's RV
CA
Posted: 08/13/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
In addition to checking the water lines, make sure you have flexible hoses on the inlet and outlet of the water pump. These hoses should bend at least 90 degrees, or loop so that vibration doesn't get to the water lines. On ours, the factory tightened down the mounting screws thruogh the rubber grommets too tight and they lost all their flex. The screw heads should just touch the rubber and barely compress it. Finally, make sure whatever the pump is mounted on doesn't act like a drumhead.
John, Winnebago Minnie 24V
