RV.Net Open Roads Forum: Help... Leaking black water valve on 2005 Jayco 26s
 > Help... Leaking black water valve on 2005 Jayco 26s
Liv2Camp
Stony Brook NY
Posted: 08/17/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
My black water tank valve appears to be leaking slighty, Any suggestions on repair? Has anyone else had this problem?
Thanks
Bill and Denise
2004 Canteen Green Nissan Titan LE
2005 Jayco 26s
Hi performance dual Cam
Outside entertainment
Customer value package
Storage drawers
2 Traveling Poodles Hershey and Skittles
USAFBILL
Alabama
Posted: 08/17/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
You might check for some "foreign" substance in the groves where the slide closes. If this is clear then next suggestion is to replace the valve.
Hornet28BHDS
Parker, PA
Posted: 08/17/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to check the valve for proper operation. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Liv2Camp
Stony Brook NY
Posted: 08/17/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
How do you change valve that is enclosed in underbelly?
Wind River
wyoming
Posted: 08/17/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I changed the gray water valve on my Jayco earlier this summer. I had to split the underbelly covering to access the valve. When finished, I used Eternabond tape to seal the underbelly. We just got back from Alaska and the Eternabond held.
BTW, be sure the black tank is empty and thoroughly cleaned!
2003 GMC 2500HD 4x4 Duramax/Allison
2004 Jayco Jay Flight 25RKS
Equal-i-zer Hitch, 3502 Ultra Fab Tongue Jack
Twin Honda 2000i w/parallel kit
