RV.Net Open Roads Forum: One of those oops questions for the tt owner
 > One of those oops questions for the tt owner
rondynowincomfort
Lebanon, OR.
Posted: 08/17/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Had to replace the battery on the tt. I asked my BIL who happend to be at our house at the time, to please undo the old battery so I could take it to the place I bought it from for the core charge. Well he did, and now I have no idea and neither does my DH which cable is the neg. and which is pos.
If this was a car battery not a problem, but these batter cables are black and white. I can't look it up because i'm not sure where the books for the tt are.
Anyone have any idea. Dh thinks the tt is probably wired like the a house would be, with the black being the positive.
Any help? Thanks.
SWD
Republic of Western Canada
Posted: 08/17/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
On my TT black is positive + and white is negative -
skipnchar
Topeka Kansas USA
Posted: 08/17/08 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
White should be negative and either black or red is positive.
NHguy
NH
Posted: 08/17/08 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
You can confirm negative by following the cables, they should connect to the chassis, that's the ground in 12 volt negative ground systems.
You can confirm the positive by checking where the cable goes, it should go to the fuse panel.
If you are just not sure get a little multimeter, they are under $20 at a home center, hardware or electronics store. Set it to the 20 volts DC scale, put the cables apart and power the converter up by plugging in the camper. DON'T let them touch metal, and don't let them touch each other when the converter is producing power. First test a good battery, put a probe onto each terminal. Then check the trailer battery cables. You can find positive and negative that way.
* This post was edited 08/17/08 09:23pm by NHguy *
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Crazy_2
New Maryland New Brunswick
Posted: 08/18/08 05:00am Link  |  Quote  |  Print  |  Notify Moderator
Fuse goes on the + lead
03 Nissan Xterra
Travel Star Sport XLT 24 FQB by Starcraft 3570 LBS Dry
Prodogy EBC, Reece Dual Cam WDH
Sixgun
Southeast, AL
Posted: 08/18/08 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Take a multi meter and set it to check which cable is the ground by putting one probe on one cable and the other probe grounded to the trailer. The one that gives you a direct reading is the ground cable.
rondynowincomfort
Lebanon, OR.
Posted: 08/18/08 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone, I will pass these along to my Dh so he can check this. I think he already has one of those meter things, but I bet it didn't even occur to him to use it.
He did tell me the next time, remember to have them mark the cables if something like this happen again.
Thank you again for your input and help, it is appreciated.
Tammala
dbbls
Missouri
Posted: 08/18/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
One post is bigger that the other. The cables will only go on one way without forcing them.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
dodge guy
Chicago, western subs.
Posted: 08/18/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
TT`s are, for the most part, wired like a house. white is neg.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
jplunkett
Virginia
Posted: 08/18/08 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Good question to post. This is not something I've had to deal with, but I will check and label the cable this weekend!
safe travels,
John & Elizabeth Plunkett
Louisa, Virginia
